STD Maintenance General new guy, new car!
new guy, new car!
new guy, new car!
Herrmanator8
06-05-2009, 08:55 PM #1
hey, new member who found this site here. Im not sure if im posting in the correct section so please bear with me, im new. I just bought a 1983 mercedes 300SD turbodiesel, and i want to make this think crank oout power! now i know these are serious tire burning machines. what are some simple things I can do to make this engine have more power off the line? and is it possible to convert it from an automatic trans to a manual trans?
Thanks,
Jon
Herrmanator8
Thanks,
Jon
Herrmanator8
06-06-2009, 08:47 PM #2
(06-05-2009, 08:55 PM)Herrmanator8 hey, new member who found this site here. Im not sure if im posting in the correct section so please bear with me, im new. I just bought a 1983 mercedes 300SD turbodiesel, and i want to make this think crank oout power! now i know these are serious tire burning machines. what are some simple things I can do to make this engine have more power off the line? and is it possible to convert it from an automatic trans to a manual trans?
Thanks,
Jon
also, what can i do to make my turbo loud like a cummins?
Herrmanator8
Thanks,
Jon
06-06-2009, 09:51 PM #3
For starters make sure its in good running order. Simply having properly adjusted linkage, cleaned and turned ALDA can make your car seem new. Otherwise read.
Herrmanator8
06-08-2009, 08:42 AM #4
i know alot about engines in general but im sorta new to some of the parts on my diesel so im not too quick on your slang like ALDA? whats that mean? are you talking about the throttle linkage?
Herrmanator8
06-08-2009, 10:59 AM #5
No, its a fuel regulation device. Check out dieselgiant.com, peachparts.com or benzworld.org for info on all of this.
Herrmanator8
06-10-2009, 07:03 PM #6
thanks for replyin-- so i checked out those sites and found out a few things but I still cant find out what the linkage is or what the ALDA is. What is the linkage and how do i adjust it to run better? How do I clean and turn the ALDA?
Thanks,
Jon
Herrmanator8
Thanks,
Jon
06-10-2009, 10:54 PM #7
Herrmanator8
06-12-2009, 10:49 AM #8
okay thanks, i figured it out and have already cleaned the ALDA but the site has no specifications on turning the ALDA and still cant find any info on blocking the EGR.
Thanks,
Jon
Herrmanator8
Thanks,
Jon
06-12-2009, 01:55 PM #9
(06-12-2009, 10:49 AM)Herrmanator8 okay thanks, i figured it out and have already cleaned the ALDA but the site has no specifications on turning the ALDA and still cant find any info on blocking the EGR.
Thanks,
Jon
Blocking the EGR or tampering with the ALDA is illegal in all 50 states. I hear a .25 piece fits in the EGR tube and that the metal surround on the top of the alda peels off like a sardine can.
Thanks,
Jon
