STD Tuning Engine How far should I tear into it?
aka rover
01-10-2012, 01:16 AM #1
1983 om617 turbo 200K runs good a little bit of a rough idle but started last week at -2 deg without being plugged in, so good compression I would think.
I have the motor out and on a stand and was wondering how far I shoud go into it?
It is a oily mess and i have cleaned it up and was going to replace all oil gaskets and seals.
Should I remove head and replace gasket, or just run it there isnt any signs of leaks.
Should I reseal main pan or just the metal small one?
The IP pump is dry and not leaky but the hand pump sprays back at me when I pump it, so a replace or rebuild is in order.
Turbo is stock but would like to upgrade it and add fuel to the motor to gain a few HP while im at this point. I have a KKK26 I took off my 930 to upgrade it? its the 3ldz from a 79. Not sure it will work or not.
Should I replace timming chain at this point and guides.
Any thoughts would be great
Cheers Ed
aka rover
Cheers Ed
01-10-2012, 01:23 AM #2
Valve adjustment, check timing chain.
Replace easy seals
if you are going to play with the IP, do it on the stand, will be much easier
Replace easy seals
TexasSuperDecel
S p o o l i n' in O/D
11
01-10-2012, 02:48 AM #3
I have 700,000 miles on the original head gasket in my OM617. If there are no noticable problems with it on a stand. I'd run it. I would do the following if I were to purchase a used OM617 or had it on a stand before install for ease of access especially if in a different chassis.
Valve cover gasket OEM $ 5.23 (
Hand primer pump OEM $15.06
Intake manifold gasket OEM $ 14.20
Turbo mounting gasket kit OEM $ 33.72
Oil filter housing to engine block gasket OEM $ 3.14
Oil pan gasket OEM $ 13.09
Timing tensioner spring OEM $ 4.72
Timing tensioner gasket OEM $ 0.91
Oil filter OEM $ 8.54
Canister type fuel filter OEM (Bosch) $ 7.83
Inline fuel filter depending on setup.
Belts.
Upper/Lower radiator hoses.
Thermostat.
1982 300SuperDecel (W126)
THE BEST OR NOTHING
TexasSuperDecel
Belts.
Thermostat.
THE BEST OR NOTHING
01-10-2012, 04:42 PM #4
I'd also do the front main seal and rear if it leaking!
dude99
01-12-2012, 11:59 PM #5
I'd do the front and rear main seals even if they weren't leaking. There a pain in the ass to do with the engine in and there cheap. Do them no forget about them later.
dude99
