STD Tuning Engine Cummins 12V turbo swap
MERCEDES-BENZ
02-15-2012, 11:59 PM #1
Has any one swaped a 12V cummins turbo which is the Hy35 i believe onto a OM617.952 or will it even work? i was thinking about doing this to a 300SD or twin turboing it using the stock turbo and the Hy35 both set ups would use a intercooler.
MERCEDES-BENZ
MERCEDES-BENZ
02-17-2012, 02:07 AM #3
I actually already read that now what about a twin turbo set up?
MERCEDES-BENZ
02-17-2012, 02:22 AM #4
Twin turbo is hard to do since there are 5 cylinders so it doesn't divide up very well, as for sequential/compound turbo setups
http://www.superturbodiesel.com/std/Thre...und-turbos
It seems a little overkill to me, I would rather have a nice vnt setup and call it done lol
dieselboy
Rotatin 5500 times a minute
680
02-17-2012, 02:59 AM #5
The hy35 is from a 24v cummins.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
MERCEDES-BENZ
02-17-2012, 03:03 AM #6
It is hmm then what is off of a 12V cummins?
MERCEDES-BENZ
diesel2fast4u
02-17-2012, 01:17 PM #7
(02-17-2012, 03:03 AM)MERCEDES-BENZ It is hmm then what is off of a 12V cummins?
In the dodge pickup,
Early 12V with rotary pump H1C with 18cm hsg no wastegate
12V linepump if I rmember correctly is HX35 with internal wastegate 12cm hsg
Grand cherokee WK (OM642)
diesel2fast4u
 6 Guest(s)
 6 Guest(s)
