STD Tuning Engine Turbo rods on N/A crank?
bad3gakk
om605 - kkk27 - w124
52
04-02-2012, 11:17 AM #1
Would 606 turbodiesel rods fit an 605 N/A crank?
Since the 606 and 605 turbodiesels share pistons and rods, you could interchange there.. but i dont know if the crank bearings are the same size...
bad3gakk
hansendk
04-02-2012, 11:32 PM #2
the crankshaft is the same std. size 47.950-47.965 mm.
but the bearings are not, turbo`s are sputter type
you cant take the conrod from a turbo and use n/a pistons the piston pins are not the same size.
hansendk
