STD Tuning Engine IP seal
IP seal
IP seal
Druk
04-17-2012, 09:28 AM #1
I'm sure there should be an O-ring or gasket between the IP and the timing cover on a 606-962 engine but can find nothing on the EPC.
I'm also sure I've read it on here somewhere but a search produces nothing.
Any ideas please?
Also, is a new LH bolt recommened for the timing wheel on the pump?
Thanks.
Derek.
Druk
Any ideas please?
Thanks.
Derek.
plurkje
turbodiesel
33
04-17-2012, 11:50 AM #2
The pump has a o-ring, should be A012 997 83 48, it's one of the attachment parts. Even without EPC I could find the number within minutes. The bolt is reuseable.
good luck
plurkje
good luck
Druk
04-17-2012, 04:23 PM #3
(04-17-2012, 11:50 AM)plurkje The pump has a o-ring, should be A012 997 83 48, it's one of the attachment parts. Even without EPC I could find the number within minutes. The bolt is reuseable.
good luck
Excellent. Many thanks. Smile
Druk
good luck
