STD Tuning Engine Can ALDA be added to NA pump
TurboWalt
04-16-2012, 03:42 PM #1
Can ALDA be added to a NA M pump? I don't think it can, but admit my pump knowledge is limited. I'm having a hard time finding a core Turbo M pump to send to Goran for my OM602 Turbo.
TurboWalt
04-16-2012, 03:55 PM #2
You can remove the A.D.A form a non turbo pump and replace it with a factory ALDA although I believe myna in Sweden builds custom external ALDA's
04-16-2012, 05:49 PM #3
If you are sending it to be modded, then I would not worry as much about finding a turbo pump. The differences can be adjusted away when the pump gets opened.
TurboWalt
04-19-2012, 01:42 AM #4
I've been informed that ALDA can be added to an ADA pump. Of course the parts are expensive.
TurboWalt
pp d
04-19-2012, 08:24 AM #5
(04-19-2012, 01:42 AM)TurboWalt I've been informed that ALDA can be added to an ADA pump. Of course the parts are expensive.
Cheaper and simple solution is pneumatic cylinder Wink
pp d
TurboWalt
04-19-2012, 03:16 PM #6
(04-19-2012, 08:24 AM)pp d
Can you explain further and post a pic of using pneumatic cylinder vs ALDA?
TurboWalt
04-19-2012, 03:42 PM #7
Finding a used alda shouldn't be hard or expensive.
jeemu
457
04-20-2012, 02:08 PM #8
(04-16-2012, 03:55 PM)willbhere4u myna in Sweden builds custom external ALDA's
If you mean Myna-Diesel? Its not Sweden, it s in Finland
jeemu
 7 Guest(s)
 7 Guest(s)
