STD Tuning Suspension Springs and sway bars for 78 300cd
crunky
03-24-2009, 02:13 PM #1
So, I have a 78 300CD and I am looking to do some minor suspension work to it. From what I have read, it looks like I might be able to use progressive springs off of a Gas coupe. Does anyone know how these compare to my stock springs? Any difference in ride height?
It also looks like I can find bigger sway bars out of a TD wagon, does it matter what years? And, where can I find these? I have tried ebay with no luck as of yet.
If its of any help, my goal here is mainly to eliminate roll while keeping a nice ride. I don't want to turn it into a sports car, I just want it to feel a little less boaty.
crunky
03-24-2009, 03:54 PM #2
Springs, same ride height, better handling.
Swaybar, turbo wagon 81 and up. Junkyards are you best bet or hitting up the other forums for people parting. Wagon springs up front with a link chopped off will probably do wonders.
crunky
03-25-2009, 12:37 AM #3
Awesome, exactly what I was looking for.. Thank you.
Now, when you are talking about wagon springs, what exactly is different about them compared to coupe or sedan springs?
crunky
03-25-2009, 01:37 PM #4
Stiffer, if you have the FSM they have a complete chart of the 8 or so different springs that the W123 came in. If you are going to cut coils the best way is to start with a stiffer spring.
Ghaniba
06-24-2009, 10:49 AM #5
Would this same info work for an '81 CD?
-Ghan
Ghaniba
-Ghan
GREASY_BEAST
06-26-2009, 05:42 PM #6
I have 2 sets of wagon springs for sale.
This post was last modified: 06-26-2009, 05:42 PM by GREASY_BEAST.
GREASY_BEAST
charmalu
09-04-2009, 12:49 AM #7
There is a 79 280CE @ PNP. Installing the rear springs in my 85 300D will
improve the handling?
There is also a 85 wagon Iam thinking about removing the front sway bar also.
since I installed the 240D 4-speed, and later used the 240D front springs to lower the front end. going into a sharp curves on a mountain road, the handling is a little mushy. most driving the ride is great.
Installing the wagon sway bar should take out the mush and stiffen it up, right?
Charlie
charmalu
Charlie
SurfRodder
Jackass Extraordinaire
611
09-04-2009, 12:57 AM #8
(06-24-2009, 10:49 AM)Ghaniba Would this same info work for an '81 CD?
-Ghan
it should... AFAIK all the front susp. is interchangeable...
OBK# 62
SurfRodder
-Ghan
OBK# 62
09-04-2009, 08:51 AM #9
(09-04-2009, 12:49 AM)charmalu There is a 79 280CE @ PNP. Installing the rear springs in my 85 300D will
Only if they are progressive.
(09-04-2009, 12:49 AM)charmalu There is also a 85 wagon Iam thinking about removing the front sway bar also.
It will help control the roll.
09-05-2009, 02:14 AM #10
(09-04-2009, 12:49 AM)charmalu ....
Charlie, Get it! And get the rear lights, fuel sender and what ever you can get from the SLS also. People always looking for those...
This post was last modified: 09-05-2009, 02:15 AM by DeliveryValve.
charmalu
09-05-2009, 02:15 AM #11
Reading in the FSM, removing the sway bar looks easy enough. HMMMM, now that I said that, it will probably be on the high end of the PITA scale
Do the progressive springs have a different look to them? are they easy to identify?
Charlie
charmalu
Charlie
09-05-2009, 02:19 AM #12
(09-05-2009, 02:15 AM)charmalu ...
Charlie
Progressive springs have tighter coil spacing in the middle of the spring while near the top and bottom ends the coil spacing is larger.
I have yet to see them on a w123.
This post was last modified: 09-05-2009, 02:20 AM by DeliveryValve.
Charlie
charmalu
09-05-2009, 07:52 AM #13
Thanks Richard. save me from unnessary work.
I was looking at that 79 Gasser, and they looked evenly spaced. thought the way I red above the Gassers had them.
Charlie
charmalu
Charlie
09-06-2009, 08:49 PM #14
(09-05-2009, 02:19 AM)DeliveryValve I have yet to see them on a w123.
My euro had them. They we stock for the 280?CE. Rear only.
