MW pump DV upgrade
MW pump DV upgrade
The DVs can be cut by a good machine shop, however that will give you a rough idle and really high EGTs.
As for getting new elements ($$$$), I don't know anyone stateside. Have you had a chance to read through the 600 page pump document?
(07-19-2012, 11:27 AM)OM616 I am looking at a couple of different DV designs to make or mod and use with the 10mm elements, but haven't settled on any one concept yet.
The cheapest way to make a change is to use a stronger DV spring.
(07-19-2012, 06:17 PM)Torkey(07-19-2012, 11:27 AM)OM616 I am looking at a couple of different DV designs to make or mod and use with the 10mm elements, but haven't settled on any one concept yet.
10mm!!! Wow. I was thinking 6.5 or 7.5. Can you get enough air in the cylinder to burn that much fuel? Probably a stupid question but I'm pretty new to this stuff.
Do you know anyone in the states that makes larger delivery valves?
(07-19-2012, 11:27 AM)OM616 I mod the 10mm element to output less fuel, they are the only size that can be consistently obtained for the MW.
I am intrigued with your statement that you are new to this stuff and you picked a very technical component to want to change, any reason why you want to change them? What is your goal?
As for anyone here in the USA, there have been a couple of shops that have done some pumps, but no one that specializes in performance work. Cost seems to be the limiting factor from what I have found.
(07-20-2012, 07:39 AM)Torkey The science of injection pumps is new to me and something I am looking at to get more performance out of my car. The car is used for endurance races. Most of the people that I compete with have more horsepower. So I am looking for more horsepower.
I understand the expense of doing an upgrade like this but I am willing to pay the price. There is a Bosche shop here in town that has done a great job of setting up the pump, but they haven't been able to find larger delivery valves and they agree that larger DVs in the next step in getting better performance.
(07-22-2012, 03:29 PM)Gearbound im looking for more fuel too. so has anyone gotten 10mm elements? cutting DV sounds like a cheap alternative to more fuel and yes this will have a bad idle but there are adjustments on the pump to correct that.
(07-23-2012, 03:46 PM)OM616 Ideally, after they are modded, the IP needs to be put on a calibration machine and the elements rebalanced as best as possible.
(07-23-2012, 04:32 PM)Torkey(07-20-2012, 12:25 PM)OM616 What it the Max EGT reading at full power you are getting?
On long straight sections of track we can hit over 1,000 degrees. Drivers are told to back off on the throttle when that happens.
(07-23-2012, 09:23 PM)raysorenson(07-23-2012, 03:46 PM)OM616 Ideally, after they are modded, the IP needs to be put on a calibration machine and the elements rebalanced as best as possible.
Has anyone ever done this to an MW pump? I like my MW pumps because they have ALDA's, rack position sensors (mine do, at least) and they just look better on paper compared to an M pump, but if nobody on Earth is going to calibrate them and play with the timing curve, then I'd rather have a turbo M pump modded.
Quote:How much boost are you running and is there an inner cooler?
Quote:The governor can be set up for aggressive track racing, but the adjustments are no where close to stock so not many Bosch shops will have a clue. I built one for a friend and eliminated the Torque Control and Max Speed governors, leaving only the Idle Governor operational. The driver had to be instrument rated for sure, but with you foot directly in control of the fueling it really went like hell, lots of smoke of course, but it could be controlled if it was not driven On or OFF all the time, lol.Ready, willing and able (with your help of course)
If you feel you are up to it, I am willing to talk you through the adjustments to get more out of the engine.
(07-24-2012, 12:46 PM)OM616 You have a late model MW with the electronic feed back circuit for the EGR I believe.
OM616 I agree with you regarding the MW being better than the M, that is why I have focused my time on the MW and not the M.
To my knowledge, I am the only one that has experience the MW in regards to tuning it outside the Stock parameters. The RW governor is a very flexible unit if one knows how to tune it.
I will offer you the same as I did Torkey, if you feel up to it, I am willing to talk you through the governor adjustments to get more performance out of it.
reaming out the pc burn holes will help a lot with egts once you have the ip where you want it. Even before getting the ip fully up to where you want enlargeing the burn holes is of value.
I am at three turns on the torque control. and still well behaved, of course with all other things adjusted for it to play well. egts top out at about 1050-1100 right now.
(07-24-2012, 08:26 PM)raysorenson Thank you for the offer. If I'm not mistaken you've authored a document that I've used with success on the '85 TD on my first conservative attempt at adjustments. Zero driveability or smoke issues after the first swipe. I intend to make another conservative set of adjustments for a little more power. This information is much appreciated.
(07-24-2012, 08:26 PM)raysorenson What I'm interested in knowing is if anyone can balance fuel flow once the elements have been replaced for larger ones and if injection timing can be adjusted judiciously for performance with an MW.
(07-24-2012, 08:26 PM)raysorenson An MW pump with larger elements is my pump of choice for the 617, but if Myna or Dieselmeken are able to offer a more rounded product with the M pump, then that's what I'll go with.
(07-24-2012, 08:26 PM)raysorenson I understand turning the DV's will make good power but the engine I intend to mod will go into an FJ40 Landcruiser (heavy brick in the wind) that will have to tow a utility trailer on occasion. It will be well intercooled with an adequate turbo, but I don't want to have to worry about high EGT's due to super long injection duration.
(07-25-2012, 12:11 PM)OM616 What do you mean my " if the injection timing can be adjusted judiciously for performance with an MW" ? The injection timing is set by rotating the pump on the engine just like any other pump, and MB uses a mechanical advance control mechanism to advance the timing as RPM is increased. I want to play with one to see if I can re-curve it how I want. Is that what you are talking about?
OM616 I would say get a quote from a pump shop to swap the elements, set the idle quantity and full load to stock settings, then you can turn it up from there. As I recall, there was a shop that would do that for $500.00 + elements.
Will stronger DV springs cause idle or other problems?
(07-29-2012, 07:45 PM)Torkey I would like to pursue the stronger DV springs. Do you know a source where I could get those?
(07-30-2012, 04:29 PM)OM616 The idle was on the edge of being lopey, but that is not a good description of how it sounded, it was not ruff, but not perfectly smooth either, it was like it was itching to go.
The springs helped the mid and top end, but that was with the 10s, 5.5s may see more of a effect.
I will have to look to see if I can find the part number for the spring I used and the specks.
(07-31-2012, 09:00 PM)sassparilla_kid(07-30-2012, 04:29 PM)OM616 The idle was on the edge of being lopey, but that is not a good description of how it sounded, it was not ruff, but not perfectly smooth either, it was like it was itching to go.
By "more of a effect", do you think it will be a good effect or negative? or unknown effect?
(08-22-2012, 01:41 PM)Torkey Thanks for the help OM616. The pump adjustments worked great and I've got more fuel than I need at the moment.
How did he get +28hp?
(08-24-2012, 12:16 PM)Simpler=Better How did he get +28hp?
Was this done on a stock MW pump? Would this be considered a "race only" tune? If i could make +28 hp for the daily commute i'd be ecstatic.
(08-25-2012, 08:18 AM)Secondaries Was this done on a stock MW pump? Would this be considered a "race only" tune? If i could make +28 hp for the daily commute i'd be ecstatic.
(08-25-2012, 08:43 AM)Torkey(08-25-2012, 08:18 AM)Secondaries Was this done on a stock MW pump? Would this be considered a "race only" tune? If i could make +28 hp for the daily commute i'd be ecstatic.
It's a stock MW pump. I don't consider it a race only tune but it does require installing an EGT. Too much fuel and not enough air equals a melted turbine. You'll also need to increase the turbo boost to compensate for the extra fuel.
(08-29-2012, 11:58 AM)OM616 You are a hero now Torkey !! Don't let it go to your head lol
Any chance you have printouts of the before and after pulls?
Ok, I was trying to be patient, but I'll be "that guy".
Can we get a hold of the write up you did for the governor settings, OM616? With a nice juicy "NOT RESPONSIBLE FOR ANY SCREWUPS YOU MIGHT PULL" disclaimer?
I know how you feel but even if the write up is just an explanation for what the individual screws do, etc, I'd be very grateful.
(08-31-2012, 03:38 PM)Secondaries Ok, I was trying to be patient, but I'll be "that guy".
Great thread, and inspiration to finish mine!
Keep up the work Mr. 616, your knowledge is invaluable !
