Throttle body to smooth superpumps?
From what I've read, VM Motori diesels use a throttle body to starve the engine on shutdown in order to reduce the crazy engine shake on shutdown (We all know how shutting down a 617 feels)
Could a butterfly be added to starve the engine of air at low rpm to smooth out the idle->2,000 rpm when using a superpump? Some kind of a setup to make it more streetable, and then disable it when flooring it?
lots of diesels use a throttle body but I have no idea how they are timed. most if not all the ones I can think of are electronic controlled either common rail or electronic pumps. Here is an example that Delphi does http://delphi.com/manufacturers/cv/power...-controls/
The older Mercedes diesel om616/om615 used throttle body because the pumps where not governed! with out the throttle body the engine would just run away!
(08-22-2012, 11:10 AM)Simpler=Better From what I've read, VM Motori diesels use a throttle body to starve the engine on shutdown in order to reduce the crazy engine shake on shutdown (We all know how shutting down a 617 feels)
I agree about balancing everything, what I'm talking about is smoothing the action when you go from a touch of pedal to say 15% pedal? As I understand it a modded pump, balanced or not, will feel like an on/off switch. I don't know firsthand, I don't have a superpump :p
(08-23-2012, 06:20 PM)Simpler=Better I agree about balancing everything, what I'm talking about is smoothing the action when you go from a touch of pedal to say 15% pedal? As I understand it a modded pump, balanced or not, will feel like an on/off switch. I don't know firsthand, I don't have a superpump :p
