*300TD hatch glass removal??
I'm trying to remove (intact) the rear hatch glass from my '81 300TD estate/wagon.
I've removed the: wiper/motor, defrost clips and chrome trim. It seems that I just have the window gasket holding the glass in place.
Should the glass come out or push in?
I have the glass sold on craigslist and would hate to break it!
Thanks!
I was hoping to have the glass out by now.
Anyone even know someone who's done this w/o breaking it? Its thin glass with a hole ground through it for the wiper. It seems awfully brittle.
Two person job or can I do it alone?
Is the gasket one piece or split?
Cut the gasket out, use WD40
(09-08-2012, 10:54 AM)Simpler=Better Cut the gasket out, use WD40
Push from the inside and have someone on the outside to hold it as it comes out. Start in a corner and take it easy or it will smash, you could also work the rubber on the outside with something stiff and plastic, don't use metal like a screwdriver. In all honesty I would cut the rubber. 9 times out of 10 it will come out ok and the 10th it will shatter into a thousand pieces. Far better to toss the rubber than the glass.
