STD Tuning Drivetrain OM603 in C124 - prop?
11-21-2012, 04:07 AM #1
Hi!
I recently bought a 300CE which I want to transform into a 300CDT with the OM603 turbo. I'm still on the hunt for a reasonably priced donor, during that time I want to gather as many info as I can.
What I don't know p.e. is, if the engine resp. transmission position of M103 and OM603 differ? In other words, if I take out the M103 & 722, will a OM603 with 722 bolt to the prop or is the prop too short or too long? Different flange dias not considered right now.
On the other hand I guess the engine could be moved forward/backward by modifying or DIY engine mounts?
Thanks! Smile
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
Hi!
Thanks! Smile
11-21-2012, 11:23 AM #2
The engine position is the same on the 300e vs 300d.
11-21-2012, 01:12 PM #3
Excellent! So a 'straight' swap and no different prop shaft needed Smile Thanks!
DiseaselWeasel
