Ksteen's W123 daily driver
Did you ever find a differential lock?
Here is my day's work :p
this might be the one Erling66 has been waiting for :p
home made 6mm pump :p
started here
already un mounted cam shaft etc. :p
and ended up with this:
so tomorrow (thursday)
it will be runed in bench, and hopefully it will be ready for the weekend
untill i get the kompressor and the PPD pump in about 1,5 week
I like the corner
Two turbos and a big pile of piping
I just had to post this machine
It's EDH's W201!
awesome sounding mean black smoking OM606 !
http://www.youtube.com/watch?NR=1&v=4E3D...=endscreen
Hi again.
I'm woundering if some one knows how to transform the electrical trigger for the speedometer to an analog with wire??
are there some "computer box's"?
I work att a local AM car Shop in Norway, so we ship from USA to Norway, every 14 days, and I am woundering If someone
"over there" could help me locate and ship it to my dealer in att Lake Erie Export in eucliud Ohio
it would help me big time
(02-19-2013, 07:00 AM)Ksteen2 I just had to post this machine
It's EDH's W201!
It's EDH's W201!
http://www.dragonaero.com/SpeedChangerMe...alPage.htm
That's about all there is out there that i've seen, aside from making one yourself.
Can I ask someone to help me a little?
I don't know what feedpump I'm going to use when my PPD pump get's home..
I was thinking maybe feed pump from Chevrolet Tahoe 6.5TD or somthing..
Is that pump big enough?
Buy one 044 pump (biltema), have a friend that uses one of these on my old 140cc pump with good results! He dont even have an pressure regulator I would recomend a pressure regulator
aha, I see :p
I'll try that one
OH MAN!!
my pump is coming tomorrow, I'll shaking and smile like an Idiot..
It's christmas all over again
(02-25-2013, 06:45 AM)Ksteen2 OH MAN!!
after much s**t with Posten norge, finaly i pick up my pump today,
i will post some pictures and startup video later to day
IT'S ALIVE!
in the video the magnet to the Idle was broken, but changed it, and then i worked, but still, idle is like a heavely tuned petrol car, like a smal 4 cyl with verry sharp cam shaft.
so tha ignition must be wrong, but it's about 25-26 deg ATDC
can some one help me with this one, I work until 3 in the morning with wrok att 8:30 today.. I'm exhausted..
but it att least started :p
http://www.facebook.com/video/embed?vide...6849095435
The video dose not work!
Here's a new video.
first start up with right adjusted pump:
http://www.youtube.com/watch?v=q8ljJxLtUVg
and a little 3rd gear pull (got stuck behinde a suspisious car, could have been a unmark police car :o )
http://www.youtube.com/watch?v=BkhIAbLMU...e=youtu.be
it's film'd with my Iphone 4s
so not a great quality, as poor as my english :p
the HX35 surges on 3rd over 1bar and from 0,5 att 4th :p
enjoy, more to come
now I've Emailed Pasi att PPD, and he said that the pump is at almost it's minimum, OH GJEEZ..
I thougt it was awesome now, what'a hell will happen when I get a bigger turbo and turne the pump up..
I seriously sceard right now :p
Nice!
the original clutch is still holding strong
have someone tryed how much power the original clutch is holding up??
it's damn fun..
about 0-100 KM/H in 5-7 sec
thanks
yeah, I must edmit, I like it my self :p
now, I've tryed the K31, but the 22cm housing is just enormus...
so tomorow i will try a holsett with 16cm house, but there is no number on the plate, so I don't know what it is yet :p
but I'll try to fin out, but I hope it will work properly
it's from a Scania truck, so it's propably a HX40/50/52
but, it will work better then the k31 with 22cm housing :p
(03-09-2013, 06:53 PM)Ksteen2 now, I've tryed the K31, but the 22cm housing is just enormus...
I've found out that it's a HX52-W with 16cm housing :p
and it spools preatty fast, next jobb is fitting the compressor )
that will be some day next week or so
pictures are coming :p
Yesterday, I was driving on a track, with mye "best friends" the police and the NPRA, hoho :p
It was on the local NAF track, it's a smooth execution path, and here is a picture from the time attack
I was number 8, the first 2wd car att all, everyone over me was 4wd, thats pretty good :p
and a picture from the "free ride" when we drift and do what ever we want :p
I'm in a spin, i was backwards att nearly 80 KM/H, damn so fuN!
Yes, it's really fun ;o
does any one know what a original 230mm clutch from a W124 300D holdes?
it's holding my 2 bar att HX52 turbo and burnout 1 and 2'nd gear, no problem att all.
probably hold the original clutch for a while, until it begins to slipp :p
yes :p
the HX35 gave to much back pressure ;p
so i've put on the HX52, but still strugeling with back pressure :o
should be able to pass 2 bars with it :o
You dont have backpressure problems with the hx52, that i can tell you There problem with max 2 bar must be somewhere else...
so now, I've found out that my silencer was the cause, and now the clutch is slipping on 3-4-5th gear, and about 2,6-2,7 bar of boost with the HX52, now i just need a even bigger feed pump :p
might use 12mm fuel line ass well :p
but first, I need a better clutch and pressure plate :p
You are doing well my friend the first indication that you are getting some real power: the clutch cant handle it anymore
When is the HX52 starting to spool? Would you say that a hx52 is an ok turbo for a daily driver or is there very little power in the 1500-2500 range?
And come on, kick your lazy friends out in the cold weather to make a video of you driving by
the HX52 is just an awesome turbo, begins spool att about 2-2500 and fukk bust about 3500
you definitly need a compressor att low rpm if you don't want a black smoke tunnel behinde you :p
and for the first time, a sliping clutch is a fun thing :p
oh, yes, I will do that some day, just need to find the spot :p
and first off all, get the pre-chamber tight'nd, it has begun leaking att cyl.6 :p
but soon, I'll get a friend to make a movie, and find my camera, and nip some fotos of how it looks to day :p
now, I just need a bigger feed pump i gues :p
A little bit late of a reply, but I've heard the newer Fords also have a lift pump between teh tank and engine that's good for more fuel flow and can be spliced right in. I don't know the details offhand
and FYI, I've fitted a 3,5" DP an exhaust back to the rear axsel, an 3" from there, but I will be runnin straight pipe untill i find a silencer that don't create back pressure :p
Straight pipe is the way to go.
I've heard good things about "aero turbine" brand mufflers, they have straight through models
I used one of those for an x-fer pump for my WATF fuel setup. It's got a 10 micron fuel filter, a water in fuel sensor and the pump itself.
But how much does it deliver?
now, a update on my car
this is what 2,7 bar of boost did:
then it togheter agen, and then I had to do this:
and, here is the s.o.b that ruined it all :p :
and some results after changing the rims tires and springs:
little rusted wheel arches, but that will be swapped for new one's :p
have some one tried the OEM part from summit racing for this car?
the OEM at Veng her in norway is bad fitment xD
Now, a picture and a video of my 123 with HX52 and 1,5bar of boost
Hope You enjoy
short poor video, but sooner or later, I need to catch it :p
