STD Maintenance General Broken GlowPlug OM606
olefejer
03-31-2013, 03:48 PM #1
Hi
Just removed 2 glowplus from my OM606
There is a great guide here
https://sites.google.com/site/alanmcreyn...cedesom606
But regarding using Ø4 drill and M5 Tread not worked for me.
Meaby it was as i had the BERU in
Thats why i used Ø7 drill and made a 30 mm long M8 and then it got out GREAT :-)
This post was last modified: 03-31-2013, 03:51 PM by olefejer.
1996 MB SL320 Now OM606 7 mm pump elements (myna), KKD manifold, HE341VE, 3,5" downpipe, 3" exhaust, big IC, 722.6 gearbox controller, also controls (Turbo VNT, EGT, BOOST, EGP.)
olefejer
Hi
03-31-2013, 07:20 PM #2
I'm recommending a chasing tap, Bosch glowplugs, and dielectric grease to my friend with a new 606
Glad to hear you got it out
Druk
04-01-2013, 02:39 AM #3
I've gotten all my gloplugs out without a problem but wondered if it would be good to put a drill through the glo diameter (ie not the thread) to clear out any build-up of carbon before I put them back.
Any thought on this please? 606.962 engine.
Druk
HaavardPYA
04-01-2013, 08:29 AM #4
I drilled a hole and tapped in an big torx. Worked worked very wellSmile
HaavardPYA
TheDon
606 Power!!
247
04-03-2013, 01:13 PM #5
(04-01-2013, 02:39 AM)Druk I've gotten all my gloplugs out without a problem but wondered if it would be good to put a drill through the glo diameter (ie not the thread) to clear out any build-up of carbon before I put them back.
use an om606 glow plug reamer
TheDon
fcp
04-06-2013, 04:49 PM #6
How did you remove the electrode in the centre of the plug before drilling?
I have a head on the bench with the same problem right now, with plug snapped off level and electrode protruding so I can't drill out.
On another head I tried leveraging the electrode with vice grips, but just broke the electrode off level Sad
I was planning to use high-speed turbing grinder & 3mm carbide end mill to try to cut back electrode, but perhaps you have a better solution?
fcp
olefejer
04-07-2013, 09:08 AM #7
(04-06-2013, 04:49 PM)fcp How did you remove the electrode in the centre of the plug before drilling?
used a tool dont know the word :-)
but one like this
http://www.globalindustrial.com/g/tools/...iers-95591
turned it clockwise and anticlockwise until it broke off in the button.
Then you are free to make the thread and pull it out
olefejer
but one like this
SurfRodder
Jackass Extraordinaire
611
04-24-2013, 12:31 AM #8
(04-07-2013, 09:08 AM)olefejer used a tool dont know the word :-)
but one like this
most people here call them "Vice Grips", the name brand of some of the better ones...
OBK# 62
SurfRodder
but one like this
OBK# 62
 6 Guest(s)
 6 Guest(s)
