500BHP DRIFT PROJECT
um hell yea!
where the hell is the "like" button :p
is this a M3 or a M5 tranny?
M5 then
(04-16-2013, 05:58 AM)Ksteen2 M5 then
nice work
I would take the bell to a machinist, it should only be $100 or so to get it surfaced-shouldn't be much harder than a block or head.
That cage is beautiful
Nice work, clean welds too! Bummer the bell housing wrapped. Can you guys get that heat stop gel? I use it here sometime when welding works great..
P.S. didn't know you could get Snap-On tools in N-Ireland.
(05-30-2013, 08:16 PM)Duncansport Nice work, clean welds too! Bummer the bell housing wrapped. Can you guys get that heat stop gel? I use it here sometime when welding works great..must look for that gel.
(05-31-2013, 05:57 AM)mantahead(05-30-2013, 08:16 PM)Duncansport Nice work, clean welds too! Bummer the bell housing wrapped. Can you guys get that heat stop gel? I use it here sometime when welding works great..must look for that gel.
gonna bolt housing to heavy metal next time.
yea, plenty of snap on dealers over here.
Snap-On was on "How it's made" last night. After seeing what goes into their ratchets, they're definitely worth the $$ if you're doing any heavy work.
(06-13-2013, 09:58 AM)winmutt Oh thats nifty, what is the cost on such a thing? Maybe a cheap alternative to a sportline box?works out about £95 home, should be cheaper postage for you as its from USA.
I love the technical jargon here "steering quickener" haha
You mounting that in car at column base?
(06-17-2013, 08:00 AM)maKe- That doesn't work with rack and pinion steering? Yours is with recirculating ball?
W211 steering rack is approx 2.8 turns vs 3.3 on w210. I'd like to get my W210 steering quicker but quick way to happiness is not easy on this car...
(07-21-2013, 11:29 AM)sale94 What did you do to fit the om606 in a w202? Custom motormounts? And how hard was it to fit the supra backend? Im planning on building 606 in my w202.
(07-21-2013, 05:13 PM)mantaheadOkey, what motormounts did you use?(07-21-2013, 11:29 AM)sale94 What did you do to fit the om606 in a w202? Custom motormounts? And how hard was it to fit the supra backend? Im planning on building 606 in my w202.
just set engine in, sitting forward slightly, don't want to modify firewall as not allowed on drift cars anymore over here.
supra back end was a big job, a lot of cutting and modifying.
4" downpipe on RHD - thats good work! I have a 3.5"(at turbo) to 3" (DP) one on my W124 RHD with about 10mm of clearence all round.
if you have 10mm all around, its a 20mm space, and a 4" os 25.4mm bigger, si if you hammer it little bit it should fit
made a start on exhaust manifold, 4 inch downpipe on right hand drive
Armagh-20130903-00544.jpg by mantahead, on Flickr
Armagh-20130912-00567.jpg by mantahead, on Flickr
Armagh-20130912-00574.jpg by mantahead, on Flickr
Armagh-20130913-00581.jpg by mantahead, on Flickr
tapered pipes go through flange and start taper off right at head.
Armagh-20130912-00564.jpg by mantahead, on Flickr
cheers guys,
all welded up tonight.
Armagh-20130917-00592.jpg by mantahead, on Flickr
Armagh-20130917-00594.jpg by mantahead, on Flickr
Armagh-20130917-00591.jpg by mantahead, on Flickr
I thought you were building a 250 std?
