STD Tuning Engine OM605
OM605
OM605
ravenxm
03-17-2013, 02:52 AM #1
Hi here
my name is Lev i"n new in diesel world
i"m from israel so please HELP)))))
made some projects at past in petrol now diesel powed needed
i have w201 body with 605engine
searchin for optional upgrade for 250 - 300 bhp
without opening an engine
turbo+methanol+coller+bigger elements
THX
need youre advises
places to buy or order things
what problems can i meen etc
questions are
what turbo should i use
where can i take elements to fuel pump
what is the boos i can safely drive
is water methanol injection needed or not/?
etc
what caN I DO???
This post was last modified: 03-17-2013, 04:50 AM by ravenxm.
ravenxm
Hi here
THX
need youre advises
questions are
etc
what caN I DO???
Booster
03-19-2013, 04:09 AM #2
Holset hx35 7mm pump elements. With the supporting mods/ exhaust and inlet your good for around 400bhp?
Kkd make exhaust manifolds to suit holsets,
Pump talk to dieselmeken user on the forum.
Auto or manual? If the latter think about a new clutch!!
Other people will help you with other details. There is a project around with this set up so have a search!
Edit: you will need an intercooler don't NEED meth....
This post was last modified: 03-19-2013, 04:10 AM by Booster.
Booster
TheDon
606 Power!!
247
03-19-2013, 04:53 PM #3
add a nice intercooler as well. Plus a transmission that can handle it.
TheDon
Eric78
03-20-2013, 01:15 AM #4
(03-19-2013, 04:09 AM)Booster Kkd make exhaust manifolds to suit holsets,
Got link? I found a website for Kkd motorsport but couldn't find manifolds on the site. How much for one for an OM605?
Eric78
Booster
03-22-2013, 10:12 AM #5
(03-20-2013, 01:15 AM)Eric78
http://www.kkdmotorsport.com/kauppa.php?...1270679050
Booster
ravenxm
04-14-2013, 11:57 AM #6
(03-22-2013, 10:12 AM)Booster
manifold i weld by myself
no problems with stainless 316SS
Another newbie question
protection??
what is the safe boost to drive like that?
28PSI 35 psi?
do i need an EGT gauge
afr gauge?
ravenxm
protection??
28PSI 35 psi?
afr gauge?
Booster
04-15-2013, 02:19 AM #7
Don't know where boost levels start to break things but people with just forged rods are running 3bar!
Egt will give you a good idea how its running! Really want to keep them down!
Booster
ravenxm
04-15-2013, 04:26 AM #8
(04-15-2013, 02:19 AM)Booster Don't know where boost levels start to break things but people with just forged rods are running 3bar!
where can i get forget rods??
is there any sites for tuned parts for my engine?
This post was last modified: 04-15-2013, 04:28 AM by ravenxm.
ravenxm
Eric78
04-15-2013, 04:44 AM #9
(04-15-2013, 04:26 AM)ravenxm
http://www.stenparnermotor.se/default.aspx?NodeId=43
Not sure there to get other parts for them, actually I'm not sure what can be done to the inside of the engine apart from rods, pistons, larger valves, stiffer valve springs & maybe a custom cam grind.
I don't know if you can get a stronger crank shaft for them, or even need to.
Eric78
EDH_Performance
04-15-2013, 06:24 AM #10
Do not buy these swedish rods, they are super thin in the small end! Don`t like high rpm`s...Try to search for eagle rodsSmile
What you really need is stiffer valvesprings and camshafts, stock rods hold pretty goodBig Grin
EDH_Performance
Eric78
04-16-2013, 01:21 AM #11
(04-15-2013, 06:24 AM)EDH_Performance What you really need is stiffer valvesprings and camshafts, stock rods hold pretty goodBig Grin
Can you recommend a maker/supplier of valve springs suitable for an om60x twin cammer?
Eric78
EDH_Performance
04-16-2013, 08:00 AM #12
(04-16-2013, 01:21 AM)Eric78
Here is one Norwegian one, this is the one i have...Can handle up to 8000rpm and fits with the stock om60x retainer, BUT requires a flat bottomshims ( very easy to make, i just used a plain washer from a nut and bolt shop)
http://kmcams.com/product_info.php?cPath...cts_id=885
Contact information: post@kmcams.com
EDH_Performance
ravenxm
04-16-2013, 10:39 AM #13
Damn i dont speak this group of languages))))
TNX Peonle i"ll use google translate
an other question i'm ordering 7.5mm 140cc fue l pump
what aditional turbo i can use to get 300hp exept HX35 (it's realy hard to find it in israel)>
ravenxm
 18 Guest(s)
 18 Guest(s)
