STD Tuning Engine OM651 tuners
OM651 tuners
OM651 tuners
AlanMcR
mind - blown
400
04-16-2013, 02:53 PM #1
The specs for the OM651 (2.2L compound turbo I4) are fantastic for my purposes. Unfortunately the engine computer comes with many inter-dependencies on the rest of the vehicle computers. Is there a tuner out there who can simplify / disable these dependencies?
I don't need more power, less would actually be OK (sacrilege, I know). I want the torque, fuel economy, light weight and compact size.
AlanMcR
Mark_M
04-16-2013, 04:35 PM #2
This thread will explain the problem http://www.superturbodiesel.com/std/thread-4062.html
This thread might be usefull to you as well http://www.superturbodiesel.com/std/thread-3170.html
Mark_M
Eric78
04-17-2013, 01:10 AM #3
(04-16-2013, 04:35 PM)Mark_M This thread might be usefull to you as well http://www.superturbodiesel.com/std/thread-3170.html
I was just about to suggest that a complete after market ECU would be the best route.
Eric78
AlanMcR
mind - blown
400
04-18-2013, 07:53 PM #4
Thanks for the links. The after market ECU is appealing, but I don't think that they work with the piezo injectors yet.
AlanMcR
Mark_M
04-18-2013, 08:11 PM #5
the Bosch and the Skynam definitely do and I think the Adaptronic can as well. Its really your only option to be honest. Been here before as well when I was looking to run a modern diesel engine. I looked at the TDV6 and TDV8 and found the engines were pretty cheap and then I found out why, the EMS costs a fortune!
Mark_M
