STD Tuning Engine om606 engine weight
om606 engine weight
om606 engine weight
dirtydiesel
04-27-2013, 05:40 PM #1
I searched and couldn't find a definative weight, so when i pulled mine this wekend i weighed it.
It is a 606.692, fully dressed with every ancilliary full of oil, weighed 245kg
[Image: 2013-04-25_22-21-31_927_zps97d1f09e.jpg]
[Image: 2013-04-26_18-39-52_604_zps9e74f582.jpg]
dirtydiesel
04-27-2013, 10:10 PM #2
208kg for LS1 all accessories with flex plate. Probably dry.
In case you wanted to compare.
mantahead
04-28-2013, 06:50 AM #3
good to know the weight. The 606 is a heavy beast and so are mb chassis.Smile
what you putting it into Dirty Diesel?
This post was last modified: 04-28-2013, 06:55 AM by mantahead.
mantahead
04-28-2013, 06:25 PM #4
540lb? psshhh weigh a 617 some time!
This post was last modified: 04-28-2013, 06:28 PM by Simpler=Better.
dirtydiesel
04-29-2013, 06:19 AM #5
(04-28-2013, 06:50 AM)mantahead good to know the weight. The 606 is a heavy beast and so are mb chassis.Smile
At 245kg fully dressed it think it's actually quite light, there is probably 10kg of excess pipes and cabling because of the very rough way i cut everything to take it out.
I am going to be building a tube buggy for offroad competition events
I might start a thread as i plan on changing the accessory pack on the engine, remoting the oil and fuel filters, fitting a bosch ve pump and playing around with compound turbos
dirtydiesel
mantahead
04-29-2013, 04:21 PM #6
sounds like fun.
mantahead
sounds like fun.
04-29-2013, 08:44 PM #7
I don't think it's heavy either. I posted the LSx weight comparison because those things are considered very light for the torque they deliver.
 10 Guest(s)
 10 Guest(s)
