STD Other Projects OM616 building with VE pump
Pages (2): 1 2 Next
04-28-2013, 01:26 PM #1
OM616 building with VEpump and turbo of OM602
VE pump
This post was last modified: 04-28-2013, 01:46 PM by offroaddieselhu.
offroaddieselhu
VE pump
04-29-2013, 09:27 AM #2
Interesting the VE is a rotary pump correct?
04-29-2013, 02:42 PM #3
(04-29-2013, 09:27 AM)willbhere4u Interesting the VE is a rotary pump correct?
yes
offroaddieselhu
yes
04-29-2013, 05:53 PM #4
That should be cool
That should be cool
04-29-2013, 08:59 PM #5
I've wanted to do something like this for a while glad to see it being attempted Smile
04-29-2013, 09:31 PM #6
Like a Bosch VE?
Those things can throw some serious fuel, even in stock form.
Just fitted one to my 318 perkins within the past couple months.
Like a Bosch VE?
04-30-2013, 05:53 AM #7
It will be MB207 bus with sof turbo. Only with max 0.7 bar charge pressure. 10x2.3 pump. It is just to have bit greater torque,and to optimlizate the consumption. I would like to hold the consuption on the same lever, even if the engine is stronger.
MB 207
BOSCH VE
This post was last modified: 04-30-2013, 06:18 AM by offroaddieselhu.
offroaddieselhu
MB 207
BOSCH VE
05-01-2013, 06:27 AM #8
I shuold pass to here the pump.
offroaddieselhu
GeorgeHasmanda
05-02-2013, 10:49 AM #9
From wich car is the VE pump?
GeorgeHasmanda
05-02-2013, 12:41 PM #10
(05-02-2013, 10:49 AM)GeorgeHasmanda From wich car is the VE pump?
This is speceal pump from Bosch part. Builed 10 element. It is just for 100-120 HP.
offroaddieselhu
05-02-2013, 08:29 PM #11
10mmx2.3? Lame Wink
My pump is 12mm from the factory
10mmx2.3? Lame Wink
05-03-2013, 05:13 AM #12
(05-02-2013, 08:29 PM)MFSuper90 10mmx2.3? Lame Wink
Huh
offroaddieselhu
Huh
GeorgeHasmanda
05-04-2013, 03:10 AM #13
(05-02-2013, 12:41 PM)offroaddieselhu
When can I make VE pump on OM604, what stock pump I need?
GeorgeHasmanda
05-04-2013, 04:15 AM #14
(05-04-2013, 03:10 AM)GeorgeHasmanda
What would you like to do with your Om 604 car? Would you like to change your Lucas pump( it's waste?) or you want tunning?
This post was last modified: 05-04-2013, 04:22 AM by offroaddieselhu.
offroaddieselhu
05-04-2013, 11:30 PM #15
(05-03-2013, 05:13 AM)offroaddieselhu
Huh
You stated earlier you had a 10x2.3 pump. I took that as you meant a 10mm head and rotor, and a 2.3mm camplate?
Maybe we were talking about completely different things Big Grin
Huh
05-05-2013, 05:40 AM #16
What you mean 12mm?
offroaddieselhu
What you mean 12mm?
05-05-2013, 07:19 AM #17
3 mm...
offroaddieselhu
3 mm...
05-05-2013, 11:33 AM #18
I probe VE pump
offroaddieselhu
I probe VE pump
05-05-2013, 12:58 PM #19
(05-05-2013, 05:40 AM)offroaddieselhu What you mean 12mm?
I mean the head on my VE pump is 12mm.
05-05-2013, 02:44 PM #20
(05-05-2013, 12:58 PM)MFSuper90
what is 12 VE pump ?
offroaddieselhu
05-05-2013, 08:17 PM #21
(05-05-2013, 02:44 PM)offroaddieselhu
I dont think I am understanding what you are asking. Sorry for clogging up your thread! Tongue
GeorgeHasmanda
05-07-2013, 01:25 AM #22
(05-04-2013, 04:15 AM)offroaddieselhu
(05-02-2013, 12:41 PM)offroaddieselhu This is speceal pump from Bosch part. Builed 10 element. It is just for 100-120 HP.
I have OM604 without pump and i don't like ECU.
GeorgeHasmanda
05-07-2013, 04:44 AM #23
(05-07-2013, 01:25 AM)GeorgeHasmanda
(05-04-2013, 03:10 AM)GeorgeHasmanda When can I make VE pump on OM604, what stock pump I need?
What is your plan with your car?
offroaddieselhu
05-18-2013, 09:02 AM #24
high-pressure pipe folding
(05-18-2013, 09:02 AM)offroaddieselhu high-pressure pipe folding
This post was last modified: 05-18-2013, 09:04 AM by offroaddieselhu.
offroaddieselhu
05-18-2013, 04:16 PM #25
http://www.youtube.com/watch?v=cEDA385F4QM
(05-18-2013, 04:16 PM)offroaddieselhu
http://www.youtube.com/watch?v=SKidmsVM8E0
This post was last modified: 05-18-2013, 04:21 PM by offroaddieselhu.
offroaddieselhu
05-20-2013, 06:26 AM #26
[quote='offroaddieselhu' pid='51783' dateline='1368885750']
[/q
without pre-charged http://www.youtube.com/watch?v=PUcb5G9s0RY
offroaddieselhu
[/q
05-20-2013, 07:25 PM #27
Looks good!
Looks good!
05-24-2013, 02:46 AM #28
older VE pump OM606 http://www.youtube.com/watch?v=CoiCIz1HyBM
Big GrinBig GrinBig Grin
(05-20-2013, 07:25 PM)MFSuper90 Looks good!
This post was last modified: 05-24-2013, 02:47 AM by offroaddieselhu.
offroaddieselhu
05-24-2013, 03:30 PM #29
work on OM616
(05-24-2013, 03:30 PM)offroaddieselhu work on OM616
http://www.youtube.com/watch?v=YzrBixPlRjI
This post was last modified: 05-24-2013, 03:36 PM by offroaddieselhu.
offroaddieselhu
work on OM616
05-29-2013, 06:29 AM #30
The changes good in the car.
And now will come the next step: TURBO
offroaddieselhu
05-29-2013, 07:41 AM #31
The pump looks like it came there from the factory Smile
05-29-2013, 07:46 AM #32
(05-29-2013, 07:41 AM)Simpler=Better The pump looks like it came there from the factory Smile
Thaks,
From mini factory Big Grin
I would try this kind of pump (VE) on a BIG POWER engine!
This post was last modified: 05-29-2013, 08:15 AM by offroaddieselhu.
offroaddieselhu
Thaks,
05-29-2013, 05:07 PM #33
I run that same pump on my 400 cubic inch Perkins pulling tractor. Pushes alot of fuel, more fuel than it can take without a turbo!
06-05-2013, 05:35 AM #34
"new" injektor
offroaddieselhu
"new" injektor
06-06-2013, 04:20 PM #35
(06-05-2013, 05:35 AM)offroaddieselhu "new" injektor
1.9 td vw
offroaddieselhu
1.9 td vw
06-06-2013, 04:34 PM #36
Are you only using the tips?
Or are the hole injector bodies the same?
What are the benefits?
This post was last modified: 06-06-2013, 04:35 PM by MFSuper90.
06-06-2013, 04:40 PM #37
(06-06-2013, 04:34 PM)MFSuper90 Are you only using the tips?
It's works quieter, better injection (spraying)
This post was last modified: 06-07-2013, 01:37 AM by offroaddieselhu.
offroaddieselhu
06-06-2013, 09:11 PM #38
More power? I am looking to put injectors in my om617, but I am not sure which to choose
06-07-2013, 05:16 AM #39
(06-06-2013, 09:11 PM)MFSuper90 More power? I am looking to put injectors in my om617, but I am not sure which to choose
I don't know how it's works in inline pump, but it's works on 150 bar. The quantity maybe you can change but the preinjection will be lower. (but it will not be god probably.
Offroaddieselhu
offroaddieselhu
Offroaddieselhu
GeorgeHasmanda
06-10-2013, 12:42 PM #40
(05-07-2013, 04:44 AM)offroaddieselhu
(05-04-2013, 04:15 AM)offroaddieselhu What would you like to do with your Om 604 car? Would you like to change your Lucas pump( it's waste?) or you want tunning?
Hello,I have OM604 with OM601 injection pump.Engine didn't cold start
without start spray,fluctuating idle,some explosions in exhaust and white smoke,timming is 15 degrees ATDC.I tried stroboskop with piezo sensor on injection pipe on first cilinder and timming was 28 degrees BTDC.Thx
GeorgeHasmanda
OM616
10mm MW
572
06-10-2013, 01:57 PM #41
(06-07-2013, 05:16 AM)offroaddieselhu
Offroaddieselhu
The VW injectors require very fast delivery times in order operate both stages, the VE pumps have 10/12mm elements that can deliver the fuel fast enough to reach the secondary pop pressures.
With the 5.5mm elements in the inline pumps only the primary stage is being used. With 10mm elements they may be useable, but with 5.5 or 6mm they are not a good match.
OM616
Offroaddieselhu
06-10-2013, 03:34 PM #42
[/quote]
The VW basically this injector gos with 9mm element.
Offroaddieselhu
[/quote]
Hi,
If you would set OM601 injectors to own opening pressure it would work certainly, but not this is the solution!
Offroaddieselhu
This post was last modified: 06-10-2013, 03:40 PM by offroaddieselhu.
offroaddieselhu
[/quote]
Offroaddieselhu
[/quote]
Hi,
Offroaddieselhu
06-20-2013, 10:23 AM #43
150 bar injector
New strat with 150 bar injectors
https://www.youtube.com/watch?v=sNQL1mV6x_0
This post was last modified: 06-20-2013, 10:26 AM by offroaddieselhu.
offroaddieselhu
150 bar injector
06-21-2013, 04:24 AM #44
(06-20-2013, 10:23 AM)offroaddieselhu 150 bar injector
https://www.youtube.com/watch?v=Kq6XqCI8Bls
https://www.youtube.com/watch?v=2v38jwVZ...h8itXs2hZQ
offroaddieselhu
06-22-2013, 04:38 AM #45
Now we can strat to build the turbo project!
offroaddieselhu
Kozuka
I'm_Badass
334
06-23-2013, 06:43 PM #46
What collar are you using to put the VE pump to the chain drive sprocket (the om602 sprinter one?) and what VE pump are you using?
Kozuka
06-24-2013, 04:02 AM #47
(06-23-2013, 06:43 PM)Kozuka What collar are you using to put the VE pump to the chain drive sprocket (the om602 sprinter one?) and what VE pump are you using?
Hi,
I don't understand your problem. Please writte me exactly!
You can see on the photho my solution.
Offroaddieselhu
offroaddieselhu
Hi,
Offroaddieselhu
Kozuka
I'm_Badass
334
06-24-2013, 10:51 AM #48
You know, the spline adapter that fits inside the engine and drives the pump. Which one did you use, where did you source it? Trying to figure out what's involved in a VE pump conversion.
Did you have to change the drive sprocket (that is driven by the engine timing chain) because of the automatic advance?
Why did you need a spacer for the pump to the block? Was your spline adapter too long?
Devils in the details, if someone wants to replicate this. Maybe me, the 5,000rpm limit doesn't bother me in my wagon. Possibly a cheaper way to sub-300hp. 12mm head, 3.3mm cam plate, VW rabbit governer spring, big injectors, & boost. Could be a fun project.
Pic of the adapter spline collar on an om602 VE pump 310-312D sprinter van.
[Image: k32v.jpg]
This post was last modified: 06-24-2013, 01:49 PM by Kozuka.
Kozuka
[Image: k32v.jpg]
06-24-2013, 02:28 PM #49
(06-24-2013, 10:51 AM)Kozuka You know, the spline adapter that fits inside the engine and drives the pump. Which one did you use, where did you source it? Trying to figure out what's involved in a VE pump conversion.
[Image: k32v.jpg]
I welded the automatic advance.
The thin-axis goes up to the old VE Pump Parts feeder wheel drive
offroaddieselhu
[Image: k32v.jpg]
Kozuka
I'm_Badass
334
06-24-2013, 07:34 PM #50
Did you use the om602 sprinter spline adapter on the input shaft or do you have another source for them? That's the main hurdle to making this work state side is that rinky-dink spline adapter that they didn't sell here but they did in Europe. Almost willing to spend the $400 to get a whole pump for that little piece.
Kozuka
Pages (2): 1 2 Next
 34 Guest(s)
 34 Guest(s)
