STD Other Projects `94 E300 STD rolling project
Pages (2): Previous 1 2
maxypriest
05-10-2013, 08:52 AM #51
(05-10-2013, 08:28 AM)HaavardPYA Will try it tomorrow when i come home from work!Smile
Super. How difficult was it to convert the pedal set up from Auto to manual? ie put a clutch pedal in...
maxypriest
HaavardPYA
05-11-2013, 08:04 AM #52
Just get hold of manual brake and clutch pedals and swap it. It comes in one unit so it is easy to convert.
Started it today! Video is without inlet manifold.
Is it a bit noisy? Any suggestions on timing? What way should i move the pump?
http://www.youtube.com/watch?v=q1hZ7x1gmfE
HaavardPYA
Ksteen2
05-13-2013, 06:42 PM #53
What's the timing?
It should be around 20 degress atdc.
Etter tenning på disse motorene, merkelig nok..
Just explaining i norwegian, beacuse in leak of english
Words xD
1#
Volvo 940 estate 1995
Originaly a d24tic
6speed cdi box
4,5" humongus cooler
Please wait, loading boost
Ksteen2
What's the timing?
Words xD
1#
Originaly a d24tic
6speed cdi box
HaavardPYA
05-14-2013, 04:09 AM #54
Just mounted it as adviced at this forum with the "pump locker" tool, and sentered it so that the pump can be adjusted both ways.
Its not wery noisy in my opinion. Sounds almost the same as the 606.910 that stood there from factory.
I guess i will see it on the EGT's when i start driving.
Do you know where i can get one of those timing lights(tenningslampe) for these engines?
If you look at my FB profile(Håvard Humberset Sæter) you will find another video!
HaavardPYA
Ksteen2
05-14-2013, 09:49 AM #55
I adjust mine after ear, and if you listen to my video when i got the timing right, it purs like a kitten Wink
i should go verry quiet on idle, not much noise, you should hear the diesel knock, but i thought your's was a little loud :p
I'll go on facebook and listen to the other one Wink
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
HaavardPYA
05-14-2013, 02:32 PM #56
Stupid question, but don`t you need to bend the diesel lines from the pump to move it?
HaavardPYA
mantahead
05-14-2013, 03:44 PM #57
[quote='HaavardPYA' pid='51648' dateline='1368522566']
[/quote
hi,
i use one of these with the sealey timing light.
http://www.ebay.co.uk/itm/Sealey-TL95-Ti...1e6b44834a
http://www.ebay.co.uk/itm/Sealey-Timing-...1e5f5740b7
mantahead
[/quote
hi,
Ksteen2
05-15-2013, 03:24 AM #58
yes, u need to bend them a little Wink
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
HaavardPYA
07-10-2013, 09:47 AM #59
Aaah! After a month of waiting in this project the boostpipes are finally finishedBig Grin Havent got the car home from the JAAS Performance workshop yet, but I'm back from my vacation on sunday and can't wait to see the result!! JAAS made a really compact system with a/w intercooler and orginal crossoverpipe from the 606.910. Pipes, comp. house and inletmanifold will hopefully be powdercoated this weekend:-)
HaavardPYA
Ksteen2
07-11-2013, 02:41 AM #60
pictures or it didn't happen Wink
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
HaavardPYA
07-11-2013, 02:53 PM #61
Read the text! I'm not at home;-)
HaavardPYA
HaavardPYA
07-24-2013, 05:33 PM #62
Change in plans! Ordered Precicion 6766 billet turbo today! Living on water and bread next month;-)
HaavardPYA
HaavardPYA
01-02-2014, 04:32 PM #63
Little updates here for a while now.. sorry for that! The car has been up and running now for a while and i must say i`m impressed of these engines! Third gear, 2 bar boost and it spins when you floor it! Megafun! Turbo spools a little late, so I'm gonna buy the 0.82 turbinehousing instead. Also change the gearbox to automatic again. Need cruise control and comfort in the dailydriverWink
will try to make a movie soon!
HaavardPYA
