STD Tuning Engine replace vac pump with dry sump oil system.
Freefuel
07-03-2012, 08:40 PM #1
So I was thinking about fitting a dry sump oil system to an OM617, and driving it from the camshaft PTO normally used for the vacuum pump. I also hope that by doing this I can remove the stock oil pump and chain so I can shave the oil Pan as flat as can be.
This post was last modified: 07-03-2012, 08:40 PM by Freefuel.
Freefuel
07-04-2012, 01:34 AM #2
I think that's a good idea. If you do it, please post your build along way.
11-09-2012, 08:38 PM #3
Any luck on this concept ?
11-15-2012, 09:05 AM #4
Can the SLS pump run continuously as a pressure pump?
Turbo
11-15-2012, 04:28 PM #5
I am working on a similar system for the OM606.962 but it would be very interesting to follow what you come out with
(07-03-2012, 08:40 PM)Freefuel So I was thinking about fitting a dry sump oil system to an OM617, and driving it from the camshaft PTO normally used for the vacuum pump. I also hope that by doing this I can remove the stock oil pump and chain so I can shave the oil Pan as flat as can be.
Turbo
CRD4x4
CompoundSuperTurboDiesel4x4!
399
05-18-2013, 07:00 PM #6
Dry sump: This is a subject that I think needs more attention.
Is the SLS pump on the 617 up to the task of working continuously as an engine oil pump?
How would one go about this on a 606 turbo?
Any examples of a dry sump system in use on either engine?
I know the advantages of using a dry sump but what are the drawbacks, if any?
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
Alastair E
Moderator?--Nah...
266
05-20-2013, 01:59 PM #7
Cant use SLS pump as engine oil pump!
--Its flow is way too low. Its a Very high Pressure, Low Volume pump...
There's loads of bolt-on crank driven scavenge and oil-pumps that could be used...
[Image: 300TDnoplate.jpg]
Alastair E
SurfRodder
Jackass Extraordinaire
611
05-20-2013, 02:34 PM #8
I'm definitely interested to see the outcome of this project...a way to measure and compare flow and pressures between stock and dry sump would be a good thing to keep from doing some serious damage...
This post was last modified: 05-20-2013, 02:36 PM by SurfRodder.
OBK# 62
SurfRodder
OBK# 62
05-20-2013, 03:09 PM #9
I'd put in $20 if someone posted a nice writeup
