Poll: Number of MW owners vrs M owners who want a modded IP
(05-21-2013, 04:25 PM)poleshady I read that document and took a look at the IP, how do you guys manage to make all those changes to the tuning and get your hands in there with the oil filter in the way, or do you all have a remote oil filter already?
(05-24-2013, 12:12 PM)poleshady Do you have estimates of what it costs to have custom oil lines made for the remote oil filter
The new delivery valves arrived today, and from the looks of them, I think they should work better than the last ones I used in combination with 10mm elements.
The collar is much wider and there is a small flat ground in it at one spot. I am marginally concerned that with the lower idle quantities this flat will make the engine lope a bit, but I won't know until I run them. If they do lope, I will have to try other ones...
(05-29-2013, 04:11 PM)OM616 The new delivery valves arrived today, and from the looks of them, I think they should work better than the last ones I used in combination with 10mm elements.
I might have a line on a 10mm MW for a 617a, it is missing the DVs and the DV holders I guess. I have no idea what elements are in it either, (I did not build it).
I thought I would see if there was any interest in it before I tried to get more info on it.
I would have no responsibility for this pump, I am only offering to broker it so to speak for a friend if he is good with that.
