STD Tuning Engine How do you remove a 606 pump?
Bangaway
606 Turbo > Porsche Turbo
129
06-02-2013, 10:47 PM #1
I've never removed an injection pump, but I need to so I can get it modified. I found some instructions but I would like some imput from others if possible.
Instructions: http://www.w124-zone.com/downloads/MB%20...1-8410.pdf
1.) buy special tools--the basket or assempbly cage, and blocking bolt
2.)disconect groung battery line
3.)unbolt noise encapsulation (what is this)
4.)unscrew central securing bolt, left hand threaded
5.) turn crankshaft to 14 degrees plus .5 degrees...TDC...look at instructions--please explain in more detail-
6.) remove chanin tensioner--necessary?
7.) unbolt injection lines at pump
8.)detatch vacuum lines at pump
9.) unnplug plastic coupling microswitch
10.)remove cruise control
11.) ARA? unplug
12.)ELR? unplug
13.)overflow restriction, unscrew?
14.) fuel lines, remove
15.)10/2 and 10/3 bolts
16.) injection pump--counter hold injection timing device--what?
17.) forgot-- first remove intake maniflod
Do I have to remove the vacum pump? Is bolt 40/3 behind the vacuum pump?
What do you use fo the special notched wrench listed in the insturctions? What are the big things to be aware of?
Lots of questions, I know. Add what you can, if possible. I gotta get the pump out! Then back in! Thanks in advance.
This post was last modified: 06-02-2013, 10:49 PM by Bangaway.
Bangaway
11.) ARA? unplug
12.)ELR? unplug
06-03-2013, 08:14 AM #2
Yes, you have to remove the vacuum pump to get to the lefthand threaded bolt. The injection pump locking tool is also very useful:
[Image: 363264d1300292010-ip-re-re-question-ip-locking-tool.jpg]
Bangaway
129
06-03-2013, 10:12 PM #3
What does the basket do? Do I "need" it? Or is there a way to go without it.
This post was last modified: 06-03-2013, 11:20 PM by Bangaway.
Bangaway
SWL300SDL
300SDL Super Turbo / Prius Killer
35
06-25-2013, 01:26 AM #4
(06-03-2013, 10:12 PM)Bangaway What does the basket do? Do I "need" it? Or is there a way to go without it.
The basket for the vacuum pump? I ditched mine on my 603 when my pump failed. Most new or rebuilt pumps say to ditch the basket. Not to sure if the 606 needs it but I doubt it does being they are so similar.
1987 Mercedes 300SDL Super Turbo Restore/Project
SWL300SDL
Druk
06-25-2013, 02:48 AM #5
The basket holds the timing pulley in place when the pump is removed. Without it the pulley drops into the timing case.
This post was last modified: 06-25-2013, 02:51 AM by Druk.
Druk
maxypriest
06-25-2013, 04:38 AM #6
(06-25-2013, 02:48 AM)Druk
Where do I get one of these baskets? Merc dealer?
Are they expensive?!
Max
maxypriest
Max
Druk
06-25-2013, 07:21 AM #7
(06-25-2013, 04:38 AM)maxypriest Where do I get one of these baskets? Merc dealer?
Max
Read this thread...
http://www.superturbodiesel.com/std/thre...l#pid52368
I'll take measurements of mine if you feel you can fabricate one from 1mm steel. Not that complicated.
This post was last modified: 06-25-2013, 07:21 AM by Druk.
Druk
Max
Read this thread...
maxypriest
06-25-2013, 09:03 AM #8
Cripes! And the locking tool too!!!
maxypriest
06-25-2013, 11:52 AM #9
I haven't torn into a 606 by hand yet but I'm sure that there must be a way to rig it without using the special tool. Safety wire and coat hangers?
06-25-2013, 12:02 PM #10
I swapped Pumps on 606 and 603 without any Special Tool. Only for Timing i use the Mercedes Tool..
hansebanger77
boyt
06-25-2013, 04:43 PM #11
Give me part numbers of tools. And I will see what I can do on price. I get them at cost price to merc dealers
boyt
Bangaway
129
06-25-2013, 10:04 PM #12
I think this is the part number 601 589 05 14 00. In the U.S. dealer prices range from about 150 to 300. I got lucky and bought a used one from a nice guySmile I guess about two years ago the dealer price was 10 bucks then they went to 150! Thanks Mercedes.
Bangaway
boyt
06-26-2013, 01:27 AM #13
Cost price is 129 plus vat. What a rip off. Lucky I have two already. Plus the pump last cking tool. Plus the pump timimg lights
boyt
 10 Guest(s)
 10 Guest(s)
