STD Other Projects Polish OM601Turbo
Polish OM601Turbo
Polish OM601Turbo
Cobesh
04-25-2013, 05:44 PM #1
Hello,
Im from Poland.
Here is my car:
Stock w124 OM601 '89 witch 4gear manual transmision.
Now:
- K14 turbo from W210 2.9DT,
- FMIC from BMW e34 525TDS,
- exhaust manifold from Vito 2.3 DT
More on movie:
http://www.youtube.com/watch?v=nh60E_kia...e=youtu.be
First start up on vegetable oil Big Grin
Current pressure is 0.6B
Here is some smoke:
http://www.youtube.com/watch?v=zLgBCRLEghg
Om601 + K14 Turbo
[Image: imgp4389q.th.jpg]
Cobesh
Hello,
Im from Poland.
Here is my car:
Now:
More on movie:
Here is some smoke:
Om601 + K14 Turbo
04-26-2013, 09:29 AM #2
Nice Smile
Nice Smile
04-26-2013, 09:42 AM #3
looks nice I was trying to buy one of these last year but if fell through
Cobesh
04-26-2013, 10:49 AM #4
We started work on the car on Wednesday afternoon and we finished on Tuesday night.
The funny thing is that the car began to burn less fuel. Well, but the injection pump is still stock
Om601 + K14 Turbo
Cobesh
Om601 + K14 Turbo
swecias
HX40Super
40
04-26-2013, 12:47 PM #5
(04-26-2013, 10:49 AM)Cobesh We started work on the car on Wednesday afternoon and we finished on Tuesday night.
only 0.6bar ? whats beckpresure ? boost more, use electric fuel pump to stock pump...
swecias
Cobesh
04-27-2013, 04:52 PM #6
Now I changed to diesel fuel, immediately increased the pressure to 0.8 bar. I think the welds on the intake pipes are leaking, check on Monday.
I do not know the compression, I can only guess that the course of 450 + k km did his.
BTW wastegate is welded.
This post was last modified: 04-27-2013, 05:32 PM by Cobesh.
Om601 + K14 Turbo
Cobesh
Om601 + K14 Turbo
Cobesh
05-08-2013, 10:21 AM #7
http://www.youtube.com/watch?v=gdzjHFsIXNE
[Image: 92330655505465118369810.th.jpg]
Om601 + K14 Turbo
Cobesh
Om601 + K14 Turbo
Cobesh
05-20-2013, 04:40 PM #8
Here is 100-150KM/H on stock pump and 0.7b
http://www.youtube.com/watch?v=3UUlnooq65Y
This post was last modified: 05-20-2013, 04:41 PM by Cobesh.
Om601 + K14 Turbo
Cobesh
Om601 + K14 Turbo
05-21-2013, 08:45 AM #9
Vroom!
Vroom!
swecias
HX40Super
40
05-21-2013, 12:10 PM #10
make beckpresure gauge
swecias
Cobesh
05-22-2013, 12:54 PM #11
I'm afraid I do not understand
Om601 + K14 Turbo
Cobesh
Om601 + K14 Turbo
swecias
HX40Super
40
05-22-2013, 02:23 PM #12
(05-21-2013, 12:10 PM)swecias make beckpresure gauge
what pressure is in the exhaust manifold ? at full load ?
swecias
Cobesh
05-28-2013, 01:00 PM #13
This is a low-budget project. Turbo was bought for 20 euros and it was not even checked before installation. As I wrote earlier intake is not completely sealed. Within a few days it will be corrected.
Om601 + K14 Turbo
Cobesh
Om601 + K14 Turbo
swecias
HX40Super
40
05-28-2013, 02:22 PM #14
use boost gauge for watch whats hapening in your exaust manifold
swecias
05-28-2013, 02:57 PM #15
(05-28-2013, 01:00 PM)Cobesh This is a low-budget project. Turbo was bought for 20 euros and it was not even checked before installation. As I wrote earlier intake is not completely sealed. Within a few days it will be corrected.
20 euros is a nice cheap build Smile
Cobesh
05-29-2013, 05:59 PM #16
Welding the WG caused the turbine behaves like a petrol engine. You need to add a minimum of gas to clinch pompwać-even while aggressively reducing gear. Here is a video to the behavior of the turbine. Especially at the end as you can see at a speed of about 100km / h minimum addition of gas increases the pressure.
http://www.youtube.com/watch?v=Kenia8n2b...WA&index=1
Om601 + K14 Turbo
Cobesh
Om601 + K14 Turbo
swecias
HX40Super
40
05-30-2013, 10:41 AM #17
(05-29-2013, 05:59 PM)Cobesh Welding the WG caused the turbine behaves like a petrol engine. You need to add a minimum of gas to clinch pompwać-even while aggressively reducing gear. Here is a video to the behavior of the turbine. Especially at the end as you can see at a speed of about 100km / h minimum addition of gas increases the pressure.
Smile) you can use westgate by other options, like control him with exaust manifold presure. if you get big beckpresure, you lose the power (cant boost more to the engine).
swecias
Cobesh
05-30-2013, 06:54 PM #18
Wast with the turbo vacuum was controlled by a valve N75. I have a pressure relief control of another turbine. I think that in June will be all put together by the end.
Om601 + K14 Turbo
Cobesh
Om601 + K14 Turbo
swecias
HX40Super
40
05-31-2013, 01:31 AM #19
(05-30-2013, 06:54 PM)Cobesh Wast with the turbo vacuum was controlled by a valve N75. I have a pressure relief control of another turbine. I think that in June will be all put together by the end.
I wait for results Smile
here is nice foto how to mesure beckpresure
http://i128.photobucket.com/albums/p169/...um/EMP.jpg
This post was last modified: 06-01-2013, 05:07 AM by swecias.
swecias
Cobesh
06-24-2013, 05:34 PM #20
Here is some stretch
[Image: 0brz.th.jpg]
[Image: 7xnd.th.jpg]
Om601 + K14 Turbo
Cobesh
Om601 + K14 Turbo
Cobesh
10-08-2013, 06:34 PM #21
I have a new toy:
http://youtu.be/VAAbnv4bpFM
So diesel goes for razors...
Om601 + K14 Turbo
Cobesh
I have a new toy:
Om601 + K14 Turbo
 10 Guest(s)
 10 Guest(s)
