STD Other Projects OM616 building with VE pump
Pages (2): Previous 1 2
06-26-2013, 04:39 AM #51
(06-24-2013, 07:34 PM)Kozuka Did you use the om602 sprinter spline adapter on the input shaft or do you have another source for them? That's the main hurdle to making this work state side is that rinky-dink spline adapter that they didn't sell here but they did in Europe. Almost willing to spend the $400 to get a whole pump for that little piece.
This adapter you need only to OM604, 605, 606.
If you build an other engine you don't need that kind of adapter.
Offroaddieselhu
offroaddieselhu
Offroaddieselhu
06-26-2013, 07:54 AM #52
Just to be clear, if I want to put a VE pump on a 616 all I need is:
-OM616
-VE pump
-3mm shim
-New injector lines
-OM616
-VE pump
-3mm shim
-New injector lines
06-26-2013, 08:15 AM #53
(06-26-2013, 07:54 AM)Simpler=Better Just to be clear, if I want to put a VE pump on a 616 all I need is:
-OM616
-VE pump
-3mm shim
-New injector lines
1 pc
What I made on this bus is not tunning. But from this can be 120-140 hp (with turbo without smoke).
It is just from waste parts project form my friend (non profit for canoe sc)
It's ultralight.
Tunning injector inculdes more exact parts.
Offroaddieselhu
(06-26-2013, 08:15 AM)offroaddieselhu
-OM616
-VE pump
-3mm shim
-New injector lines
1 pc
It's ultralight.
Thin (17mm) axle, short axle!!!! ONLY
Offroaddieselhu
This post was last modified: 06-26-2013, 08:53 AM by offroaddieselhu.
offroaddieselhu
-OM616
-VE pump
-3mm shim
-New injector lines
1 pc
It's ultralight.
Offroaddieselhu
-OM616
-VE pump
-3mm shim
-New injector lines
1 pc
It's ultralight.
Offroaddieselhu
Kozuka
I'm_Badass
334
06-26-2013, 11:12 AM #54
-OM616
-VE pump
-3mm shim
-New injector lines
1 pc
It's ultralight.
Offroaddieselhu
-OM616
-VE pump
-3mm shim
-New injector lines
1 pc
It's ultralight.
Offroaddieselhu
So what's different between om61x & om60x? M & MW pumps fit both.
So do you know of the sprinter uses the vw style main shaft (17mm) or Cummings style (20mm)?
Kozuka
-OM616
-VE pump
-3mm shim
-New injector lines
1 pc
It's ultralight.
Offroaddieselhu
-OM616
-VE pump
-3mm shim
-New injector lines
1 pc
It's ultralight.
Offroaddieselhu
05-18-2014, 12:21 PM #55
The bus works.
Turbo making is the next
offroaddieselhu
offroaddieselhu
The bus works.
offroaddieselhu
05-22-2014, 10:03 AM #56
+ turbo
offroaddieselhu
offroaddieselhu
+ turbo
offroaddieselhu
