STD Tuning Engine OM602 project
OM602 project
OM602 project
Blip
08-13-2013, 06:11 AM #1
Hi, first post here. I have an OM602 from a manual Daewoo Musso. The handbook says it's a 602, the block says 662. I'm looking to mate this up to a mercedes autobox (722.4). Will I need to change to an IP from an automatic?
I know most would swap from auto to manual, so perhaps the best way of doing it is to find someone doing such a swap and exchange parts? (that is, if my IP is suitable?)
Some pics:
[Image: engine2.jpg]
[Image: pump.jpg]
Pump ID plate:
[Image: id_plate.jpg]
Many thanks for any info
Blip
Some pics:
[Image: pump.jpg]
Pump ID plate:
hooblah
08-13-2013, 08:33 AM #2
Hey im removing the auto box from my w210. Ill also have a 602 IP going spare when I do my conversion. You interested?
hooblah
Blip
08-13-2013, 01:46 PM #3
Hi, yes I'm interested, I'll send you a pm now Smile
Blip
Blip
08-13-2013, 03:44 PM #4
Is there a difference between injector pumps from manual and auto engines or are they the same? I've found the video below which, from 0:15, shows a part with a cable linkage on. Is that a bolt on part that goes behind the pump? If I can keep my existing IP and bolt on that extra bit then bravo
Blip
08-14-2013, 08:30 AM #5
That bolt-on part is the cruise control. The main thing you need is the vacuum control valve which bolts onto the side of the pump where that orange bolt is in your picture. I would get one and see if it fits on there.You can also try to see if 602 throttle linkage will work (the 603 cruise + linkage you saw will not fit in the smaller space on a 602).
Blip
08-16-2013, 11:45 AM #6
Thanks very much for the info. After lots of reading i'm starting to get a better picture of what I need Smile
Blip
mxfrank
08-20-2013, 08:12 PM #7
(08-16-2013, 11:45 AM)Blip Thanks very much for the info. After lots of reading i'm starting to get a better picture of what I need Smile
The 2.5 turbo's had transmissions with an extra plate in each clutch pack, I presume to handle the extra torque. I don't know if you can simply add a plate to a normal 722.4. The part numbers that I know are:
722.413 (190DT)
722.418 (300D 2.5)
You're also going to need a bowden cable link.
This post was last modified: 08-20-2013, 08:14 PM by mxfrank.
1987 Mercedes 190TD
mxfrank
722.413 (190DT)
722.418 (300D 2.5)
1987 Mercedes 190TD
Duncansport
08-21-2013, 08:10 AM #8
(08-20-2013, 08:12 PM)mxfrank
722.413 (190DT)
722.418 (300D 2.5)
You can but will need to shim the packs afterwards. You would need one extra disc and friction disc then the snap ring acts as the shim.
Duncansport
722.413 (190DT)
722.418 (300D 2.5)
mxfrank
08-21-2013, 10:15 AM #9
(08-21-2013, 08:10 AM)Duncansport You can but will need to shim the packs afterwards. You would need one extra disc and friction disc then the snap ring acts as the shim.
Would you know of any reason why a 722.418 from a 300D 2.5 wouldn't fit a 190DT?
1987 Mercedes 190TD
mxfrank
1987 Mercedes 190TD
pmj4147
T04R + TD06
42
09-03-2013, 04:17 PM #10
First of all
It's ssangyong not a daewoo
the engine is called 662LA which is licensed by SSmotor
2.9litre, idi cyl head.
and i think the manual gear is a better option
first, merc automatic gearbox will not match with borg-warner 4wd system. never ever.
second, that manual gearbox can handle aprox 300whp
but 270whp is a maximum power with ssangyong 662LA
Of course you can make more power with over 7mm
but engine can't handle...
i used that 662 since 2002 and i never saw 270whp over with durability.
IT WILL BLOW!!!!!!!!!!!!
and one more.... your musso have 4.27 final ratio
think about it..........
This post was last modified: 09-03-2013, 04:28 PM by pmj4147.
2002. 09 Ssangyong Musso SUT
OM662STP + 7.5mm + TD06-25G with customized 84mm compressor(2.4Bar)
2002. 12 Ssangyong Korando
OM662LA 2.9ltr + RS191 5.5mm stock
pmj4147
First of all
Blip
09-05-2013, 04:08 AM #11
(09-03-2013, 04:17 PM)pmj4147 First of all
The musso will be in scrapyard heaven, and the engine in a RWD car wanting no more power than 200 horsies.
[Image: mussopart01.jpg]
Thanks for the autobox info btw
This post was last modified: 09-05-2013, 04:12 AM by Blip.
Blip
 7 Guest(s)
 7 Guest(s)
