STD Tuning Engine OM606 with Dieselmekken IP
ravenxm
10-12-2013, 06:35 AM #1
https://www.facebook.com/photo.php?v=664928926874729
first of all it's an om606 engine with kkk k27 turbo
problem that i cant get no boost even aT 5k rpm i cant get over 1bar
3inch exaust
7.5mm elements
255 walbro pre pump
presure regulator
tubular manifold
i got a lot of smoke but no drive at all
ravenxm
3inch exaust
7.5mm elements
255 walbro pre pump
presure regulator
tubular manifold
10-12-2013, 08:05 AM #2
Sounds like waste gate stuck open
ravenxm
10-12-2013, 08:07 AM #3
(10-12-2013, 08:05 AM)MFSuper90 Sounds like waste gate stuck open
tnx check it now
ravenxm
tnx check it now
Gasoil
10-12-2013, 08:20 AM #4
In my Fiat Uno Turbo 1.6 I use a K27.2 from a Iveco 7,7 liter Bus, and months ago only boost at 1,0 bar, take off the turbo and was the wastegate, it not closed at 100% and exhaust gases not moves the turbine Ok. I clean it with WD40, and copper grease , hoping exhaust-intake manifold gasket from Argentina to see if it goes at 1,5 bar.
Lucky....
Gasoil
Lucky....
ravenxm
10-12-2013, 10:27 AM #5
i have exterbal tial wastegate with 1.7bar spring
ravenxm
