Diff info?
Diff info?
I thought I saw a list of diff gear ratios in here based on model and year of car...
If not does someone have that info or can a sticky be compiled?
Years, Model, Engine, Differential Ratio, Differential Case Size
R107
1st Generation mounting
1972-1980, 350 SL/SLC, M116, 3.46, 1.1 Liter
1973-1980, 450 SL/SLC, M117, 2.65 / 3.06, 1.3 Liter
1981-1985, 380 SL, M116, 2.47, 1.3 Liter
1981-1982, 380SLC, M116, 2.47, 1.3 Liter
2nd Generation mounting
1986–1989, 560SL, M117, 2.47 / 2.47 ASR / 2.47 LSD, 1.3 Liter
W114
1968-1976, 230, M180, 3.69 / 3.92, 1.1 Liter
1968-1972, 250, M114, 3.69 / 3.92, 1.1 Liter
1972-1976, 250, M130, 3.69 / 3.92, 1.1 Liter
1969-1976, 250C/CE, M130, 3.69 / 3.92, 1.1 Liter
1972-1976, 280/E, M110, 3.69 / 3.92, 1.1 Liter
1972-1976, 280C/CE, M110, 3.69 / 3.92, 1.1 Liter
W115
1968–1976, 200, M121, 3.92 / 4.08, 1.1 Liter
1968–1976, 200D, OM615, 3.92, 1.1 Liter
1968–1973, 220, M115, 3.92 / 4.08, 1.1 Liter
1968–1976, 220D, OM615.941, 3.92, 1.1 Liter
1973–1976, 230.4, M115, 3.69, 1.1 Liter
1973–1976, 240D, OM616.916, 3.69, 1.1 Liter
1974–1976, 240D 3.0/300D, OM617.910, 3.46, 1.1 Liter
W116
1973–1980, 280S, M110, 3.69, 1.1 Liter
1973–1980, 280SE, M110, 3.69, 1.1 Liter
1974–1980, 280SEL, M110, 3.69, 1.1 Liter
1973–1980, 350SE, M116, 3.46, 1.1 Liter
1973–1980, 350SEL, M116, 3.46, 1.1 Liter
1973–1980, 450SE, M117, 3.06 / 3.07, 1.3 Liter
1973–1980, 450SEL, M117, 2.65 / 3.06 / 3.07, 1.3 Liter
1975–1980, 450SEL 6.9, M100, 2.65 LSD, 1.3 Liter
1978–1980, 300SD, OM617.950, 3.07, 1.1 Liter
W123
1977–1978, 230, M115, 3.69, 1.1 Liter
1977–1983, 240D, OM616.912, 3.69, 1.1 Liter
1977–1981, 280E, M110, 3.58, 1.1 Liter
1978–1981, 280CE, M110, 3.58, 1.1 Liter
1977–1981, 300D, OM617.912, 3.46, 1.1 Liter
1978–1981, 300CD, OM617.912, 3.46, 1.1 Liter
1979–1980, 300TD, OM617.912, 3.46, 1.1 Liter
1981-1984, 300TD, OM617.952, 3.07, 1.1 Liter
1982-1984, 300D, OM617.952, 3.07, 1.1 Liter
1982–1984, 300CD, OM617.952, 3.07, 1.1 Liter
1985, 300TD, OM617.952, 2.88, 1.1 Liter
1985, 300D, OM617.952, 2.88, 1.1 Liter
1985, 300CD, OM617.952, 2.88, 1.1 Liter
Euro Spec
1981-1985, 300TD, OM617.912, 3.46, 1.1 Liter
1982-1985, 300D, OM617.912, 3.46, 1.1 Liter
1982–1985, 300CD, OM617.912, 3.46, 1.1 Liter
1978–1985, 240TD, OM616.912, 3.69, 1.1 Liter
1978–1985, 280TE, M110, 3.58, 1.1 Liter
W126
1st Generation
1981-1984, 300 SD, OM617.951 3.0L I5, 3.07, 1.1 Liter
1985, 300 SD, OM617.951 3.0L I5, 2.88, 1.1 Liter
1984-1985, 380 SE, M116.963 3.8L V8, 2.47, 1.3 Liter
1981-1983, 380 SEL, M116.963 3.8L V8, 2.47, 1.3 Liter
1982-1983, 380 SEC, M116.963 3.8L V8, 2.47, 1.3 Liter
1984-1985, 500 SE, M117.963 5.0L V8, 2.47, 1.3 Liter
1984-1985, 500 SEL, M117.963 5.0L V8, 2.47, 1.3 Liter
1984-1985, 500 SEC, M117.963 5.0L V8, 2.47 /(Euro) 2.24 LSD/(Euro) 2.47 LSD, 1.3 Liter
2nd Generation
1989-1991, 300 SE, M103.981 3.0L I6, 3.46, 1 Liter
1988-1991, 300 SEL, M103.981 3.0L I6, 3.46, 1 Liter
1986-1987, 300 SDL, OM603.961 3.0L I6, 2.88, 1.1 Liter
1991, 350 SD, OM603.97 3.5L I6, 2.82, 1.3 Liter
1990-1991, 350 SDL, OM603.97 3.5L I6, 2.82, 1.3 Liter
1986-1991, 420 SEL, M116.965 4.2L V8, 2.47, 1.3 Liter
1986-1991, 560 SEL, M117.968 5.6L V8, 2.47 ASR/2.47 LSD/2.47, 1.3 Liter
1986-1991, 560 SEC, M117.968 5.6L V8, 2.47 ASR/2.47 LSD/2.47, 1.3 Liter
Notes: 107, 114, 115, 116, 123 and 126 differentials interchangeable up to 8/85.
9/85 and newer 107 and 126 are interchangeable.
Your the man!
I'll add to it later. Got more data for other models, just got to compile it all together.
'82 300D falls under the Euro Spec category?
I could have bet that my '81 300SD has lower gearing than the '82 300D but it looks opposite?
(04-28-2011, 02:29 PM)Captain America '82 300D falls under the Euro Spec category?
(04-28-2011, 02:29 PM)Captain America I could have bet that my '81 300SD has lower gearing than the '82 300D but it looks opposite?
(04-28-2011, 02:40 PM)DeliveryValve(04-28-2011, 02:29 PM)Captain America '82 300D falls under the Euro Spec category?
My bad. I left out a whole section of 3.07 gear ratios.
But look at the engine model too. The Euro '82 has 617.912 n/a motor and the US '82 has the 617.952 turbo motor.
Anycase for everybody, if there is any misinformation in this list, please let me know and I'll correct it.
They both should have a 3.07 ratio. Perhaps a tired torque converter?
Huh. My friends 85 300td has 3.07 gears. According to that it should have 2.88. I'll look at the production date on it tomorrow.
Now we just need a interchangeable list.
Hi I realise this is an old thread but people searching for this type of info still hit this thread so it does need to be correct or corrected.
Deliveryvalve posted [in bold]
107,14,115,116,123 and 126 differentials interchangeable up to 8/85
please accept I have no practical experience with these diffs and have been relying on info sources such as this site
my goal is to put an LSD 3.69 ratio into my 74 w107 450slc,so the above info tells me I can swap a 1.1 litre casing into the space formerly occupied by a 1.3 litre casing.
As these casings are different widths,what is it that im missing?
I have 1.1 litre case,correct LSD and gears to complete the build of a 3.69 ratio LSD diff including spacer ring to utilise brand new 190e 16v LSD centre but do not have drawings of housings with dimensions so reading info here I assumed width to be same until I measured them today....
OK so whats the missing piece? different axles? im confused.
When you say width, are you measuring the distance between the C-clip grooves in the housings used to hold the carrier bearing races in?
(01-05-2013, 01:50 AM)petespipes .
(01-07-2013, 10:06 AM)DeliveryValve(01-05-2013, 01:50 AM)petespipes .
What I found in the w116 and w126, is the 1.3 liter case typically uses axles that are 2.5 cm shorter than the 1.1 liter case. The 107 most likely be the same. The only way to find out if the 1.3 liter axles would work, is to try them. They will slide into the diff with no problems, just need to space them correctly for locking in the "c" clips.
So what is the best way to get a 3.07 or 3.27 LSD in a 124 chassis? That is--where would I get one of these other than a 1987 190E 16V? I guess the simplest option is to convert a 185mm diff to an LSD. Are there any good documentations for how to do this including parts lists?
Here's a thread on various ways of transplanting lsd. It's pretty long but there's lots of helpful comments by gsxr (AMGDave). The parts go for somewhere around $900-1100 new.
http://mbworld.org/forums/e-class-w124/2...w124s.html
like 1981.10 they changed the differentials according to my documents.
before 1981-10 on w126 the 380SE versions had a 3.27differential, and the 500Se versions had a 2.82 differential, after 1981-10, they both uses a 2.47 diff.
might not be the same in the US.
Mercedes put AC Leather and power windows in every car sold in the US unless specialty ordered with out them. but LSD's are super rare they had to be ordered with it every once in awhile you see them in the very top of the range cars 560sec s600 and so on.
Hell even most of the base w201 190e in this country have leather interior ac and power windows the only car i have ever seen with roll up windows was 240d
(12-08-2013, 03:37 PM)john Anyone got the partnumbers on the early lsd diffs that will fit w123?
edit: Is this list compatible for eurospecs to? Have a guy saying he has a w126 91 diff with 2:65 ratio??
(12-08-2013, 04:35 PM)swampmonkey(12-08-2013, 03:37 PM)john Anyone got the partnumbers on the early lsd diffs that will fit w123?
a 1991 w126 diff wont be a bolt-on on a w123 or pre 1986 w126.
(02-10-2014, 06:17 AM)hannes_s Can anyone list W124 differential bearing numbers? Do not want to tear mine diff apart before actually buying new bearings.
(02-10-2014, 07:26 AM)swampmonkey(02-10-2014, 06:17 AM)hannes_s Can anyone list W124 differential bearing numbers? Do not want to tear mine diff apart before actually buying new bearings.
get me a number of the diff and i can see if i can find the propper bearings, what car/engine is it from?
Did you mean this number 160 6150 2.87 or some other from the diff housing
(02-23-2014, 12:31 PM)hannes_s Did you mean this number 160 6150 2.87 or some other from the diff housing
naa, not exactly, althou i could find from that to a few different...
more like
124-351-07-05
124-351-06-05
but the 06-05 should have bearings: A0009808402 A0009801102 at the front and
A0019802102 at the sides (aswell as A0229979847 as seal rings..)
07-05 differential had some "roller bearing not available" and showed the setup from the 06-05 differential.
DO NOT QUOTE ME ON THESE NUMBERS/BEARINGS AS 100% that will fit your car....
just checking WIS for what i could find, i am shure you could get these confirmed at your mb-dealer when you have more information about your car/differential or from another forum member...
cheers...
(03-17-2014, 05:35 PM)john question!
is 2.24 exclusive to 500sec? is it always a lsd??
(03-18-2014, 07:35 AM)swampmonkey(03-17-2014, 05:35 PM)john question!
Ive seen different information about that, but i think the later 500SE is supposed to have a 2.24 aswell as the 500SEC. up untill 1981-10 the 500SE had a 2.82, and then a 2.24.
Compared to for example the 380SE that went from 3.27 to 2.47 at the same time....
what i have heard the LSD is standard on the 500SEC, but yeah, the LSD part differs on where in the world you live, (you being a swede as me.) i have no information about the 500SE, but
the 500SEC could also be ordered with a 2.47 from what ive heard.
(03-18-2014, 10:05 AM)john(03-18-2014, 07:35 AM)swampmonkey(03-17-2014, 05:35 PM)john question!
have found a a 500 sec diff 2.24 in germany forsale. but i cant get the stupid german (they dont speak english ) to send me pics of the rear so i dont know if the lsd sign is there. but it is a 2.24 from a 500 sec before 86 so it should fit a w123. it must be a lsd right?
Is the output crazy low for a daily driver superturbodiesel?? cant find much use for my 6th gear with that diff. but i might buy it beacause of the price.
trying to get a hold of a 3.07LSD, there is a guy here in sweden currently selling one of those aswell as a 3.46LSD..
both imported from Canada, so it might be worth it to take a look just a tad north for those precious differentials
(10-18-2013, 05:00 PM)willbhere4u Mercedes put AC Leather and power windows in every car sold in the US unless specialty ordered with out them. but LSD's are super rare they had to be ordered with it every once in awhile you see them in the very top of the range cars 560sec s600 and so on.Just a nitpick... I see way more 'Tex interiors than leather interiors.
(09-28-2014, 09:51 AM)Druk 453358 2.47 non LSD from a W126 380SEL.that rules out the last digit being an 8 a LSD number...
I haven't looked, but I'm gonna say there's no way MB would put a 185mm diff in such a porky car.
(01-26-2015, 05:00 PM)raidaru does anyone know what diff comes with w210 om606.962 engine? 210mm or 185mm?
(01-29-2015, 11:32 AM)erx(01-29-2015, 10:50 AM)DuncansportMy 98 w210 e300td was 2,87(01-26-2015, 05:00 PM)raidaru does anyone know what diff comes with w210 om606.962 engine? 210mm or 185mm?
210MM diff 3.07
210MM diff 3.07
