STD Tuning Engine om602
om602
om602
llt6000
12-26-2013, 09:17 PM #1
hi
i have a w201 2.5D without turbo
and i would like very mutch to strap a turbo on too it
so what do i have too do with the diesel pump
my goal is only about 150-160 hp
do i have to get bigger elements or is there antoher option?
llt6000
hi
orion
12-27-2013, 04:06 PM #3
Primarily you need an other engine. The 602 without turbo has other pistons, valves and the oil reservoir is larger than yours. Further the IP has an ALDA.
orion
llt6000
12-27-2013, 05:12 PM #4
okay thanks but if i then go for the om605 engine can i use the pump from my om602?
llt6000
Duncansport
12-27-2013, 06:29 PM #5
(12-27-2013, 05:12 PM)llt6000 okay thanks but if i then go for the om605 engine can i use the pump from my om602?
Sure can, direct bolt on. Most parts will swap over from the 602 to the 605. EPC even shows a lot of 602 parts make up the 605..
Duncansport
