NEED (123) alternator Housing... ALL SET, THANKS
Hi everyone.. My alternator gave out and the housing is cracked, so I need a rebuildable core to have rebuilt. A good empty housing would be fine too.
The car is a 84 300D (123) with a 617a
Mine has a two belt pulley..
I have had such bad luck with chain store rebuilds that I will not do another one. Just my luck that mine has a bad housing..
ALX129 was only $120 last I checked, could be time for an upgrade?
It's a 115a alt if I remember correctly.
I think I have an alternator at home, it might even be good. I'll look when I get home and let you know.
I ran one in my 300D, you need to make up battery cables. If you're cheap you can mod the stock one. Last I knew advance auto had 2ga for stupid cheap, like $25 for 50ft when you bought the whole roll.
http://www.ebay.com/sch/i.html?clk_rvr_i..._PrefLoc=1
http://www.peachparts.com/shopforum/dies...-123s.html
You may or may not need to clock the housing to get past an AC hose, and the pulley may or may not need to be swapped.
I do have an alternator. It was a bosch reman, even says mercedes on it. Has a little noise when I spin in but it could just be because it sat for a while. If you want it let me know and we can work something out.
