STD Other Projects OM 606 building 4x4 bugy
01-21-2014, 03:14 PM #1
offroaddieselhu
offroaddieselhu
offroaddieselhu
CRD4x4
CompoundSuperTurboDiesel4x4!
399
01-21-2014, 03:48 PM #2
(01-21-2014, 03:14 PM)offroaddieselhu OM 606 building 4x4 bugy
offroaddieselhu
YES! Rock on!!
Is it going to be a tube chassis? What's the end goal?
Looking forward to pics when you have them!
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
offroaddieselhu
YES! Rock on!!
01-23-2014, 04:08 AM #3
Hi,
It'll be tube chassis.
I'll make only the engine for it.
THe final goal 400+ Hp.
Offroaddieselhu
YES! Rock on!!
[/quote]
offroaddieselhu
Hi,
Offroaddieselhu
YES! Rock on!!
[/quote]
pryantcc
01-23-2014, 04:48 AM #4
Sounds very good! What's the plan for transmission?
pryantcc
01-23-2014, 05:26 AM #5
(01-23-2014, 04:48 AM)pryantcc Sounds very good! What's the plan for transmission?
Hi,
772.6 gearbox
Offroaddieselhu
offroaddieselhu
Hi,
772.6 gearbox
Offroaddieselhu
03-03-2014, 04:51 PM #6
hi
bi-turbó
offroaddieselhu
hi
bi-turbó
CRD4x4
399
03-04-2014, 08:04 AM #7
What turbos are you compounding?
Is that larger one a variable geometry?
Looking good!
CRD4x4
Looking good!
03-04-2014, 09:55 AM #8
(03-04-2014, 08:04 AM)CRD4x4 What turbos are you compounding?
Looking good!
It's offroaddieselhu, you ought to know better than to ask if it's variable or not Wink
I pretty sure everything he builds has a variable on it! Big Grin
Looking good!
03-04-2014, 02:36 PM #9
(03-04-2014, 09:55 AM)MFSuper90
Looking good!
Smile
offroaddieselhu
2 pcs gtb 2260 turbó
offroaddieselhu
This post was last modified: 03-04-2014, 02:37 PM by offroaddieselhu.
offroaddieselhu
Looking good!
Smile
offroaddieselhu
offroaddieselhu
03-22-2014, 03:43 PM #10
this is the basic http://www.youtube.com/watch?v=9HV-sd5nL...h8itXs2hZQ
offroaddieselhu
offroaddieselhu
offroaddieselhu
CRD4x4
399
03-26-2014, 10:22 AM #12
Nice pipes! Did you make them yourself? Heat + BFH? What wall thickness?
(03-26-2014, 07:01 AM)offroaddieselhu https://scontent-b-fra.xx.fbcdn.net/hpho...9999_n.jpg
offroaddieselhu
CRD4x4
offroaddieselhu
GeorgeHasmanda
03-26-2014, 05:51 PM #13
(03-22-2014, 03:43 PM)offroaddieselhu this is the basic http://www.youtube.com/watch?v=9HV-sd5nL...h8itXs2hZQ
offroaddieselhu
What timing do you use for VE pump? 15 ATDC?
GeorgeHasmanda
offroaddieselhu
03-27-2014, 05:58 AM #14
(03-26-2014, 10:22 AM)CRD4x4 Nice pipes! Did you make them yourself? Heat + BFH? What wall thickness?
offroaddieselhu
These pipes are not the best but I will take better and I will send you more photos about the best version too.
offroaddieselhu
(03-26-2014, 05:51 PM)GeorgeHasmanda
offroaddieselhu
Hi,
I've made this engine about 6 years ago. This is a socalled basic engine, that has 0.9-1 mm ATDC.
If I'll make the new I'll messure the new setting and I'll writte you.
Offroaddieselhu
This post was last modified: 03-27-2014, 06:01 AM by offroaddieselhu.
offroaddieselhu
offroaddieselhu
offroaddieselhu
offroaddieselhu
Hi,
Offroaddieselhu
03-28-2014, 01:29 PM #15
Hi
offroaddieselhu
offroaddieselhu
Hi
offroaddieselhu
04-03-2014, 05:03 AM #16
hi
exhaust
This post was last modified: 04-03-2014, 05:11 AM by offroaddieselhu.
offroaddieselhu
hi
exhaust
04-13-2014, 03:51 PM #17
test
http://www.youtube.com/watch?v=i7hwXNnAY2U
offroaddieselhu
offroaddieselhu
test
offroaddieselhu
04-15-2014, 03:10 PM #18
(04-13-2014, 03:51 PM)offroaddieselhu test
offroaddieselhu
1000/ 90+ccm
offroaddieselhu
offroaddieselhu
1000/ 90+ccm
04-19-2014, 09:00 AM #19
i have cut
offroaddieselhu
offroaddieselhu
i have cut
offroaddieselhu
sorin_cel
71
04-21-2014, 07:53 AM #20
how have you shapped the oval pipes for the exhaust manifold?
sorin_cel
04-21-2014, 02:34 PM #21
(04-21-2014, 07:53 AM)sorin_cel how have you shapped the oval pipes for the exhaust manifold?
hi,
somebody made for me
offroaddieselhu
offroaddieselhu
hi,
offroaddieselhu
04-29-2014, 04:07 AM #22
hi
new oval pipes
offroaddieselhu
offroaddieselhu
hi
new oval pipes
offroaddieselhu
04-17-2015, 03:39 PM #23
Hi
offroaddieselhu
offroaddieselhu
Hi
offroaddieselhu
04-17-2015, 03:42 PM #24
(04-17-2015, 03:39 PM)offroaddieselhu Hi
offroaddieselhu
offroaddieselhu
offroaddieselhu
mytmousemalibu
04-18-2015, 01:30 AM #25
Where could I get those oval pieces in 304 stainless steel? Are there some bigger than the stock port size? I have fully ported my cylinder head and the exhaust ports are a fair bit larger than stock size. These transition pieces would save me a lot of added welding work.
_______________________________________________________________
87' 300D daily driver, under the knife for a OM606 superturbo build!
82' 300SD~ Parting Out
93' 300TE~ Parting Out
89' 300E  ~ Parting Out
83' 240D~ Project "Cheap Drive"
03' 2500HD Dmax, lots of goodies
88' RX7 10th AE, 13B rotary Track Car Project
73' Datsun 510 wagon~ future project
79' Camaro Z28~ future project
mytmousemalibu
hents99
04-18-2015, 01:47 AM #26
We buy those cones from local hardware shop, it`s central heating pipe. It`s for connecting pipes with different diameter. I suggest to use 60,3-33,7mm cone. Cut smaller end to correct size and you get short cone.
www.elbe.ee - MB performance parts.
hents99
 10 Guest(s)
 10 Guest(s)
