STD Tuning Engine Taking the little 617 turbo to the max...maybe
lgreeley83
Mr. Rumbles
02-06-2014, 02:56 PM #1
I'm asking for input from you turbo genius guys. I have a Dieselmeken 6mm pump on my 617.
I have the stock garret modified for 60 trim. I need to upgrade as I have nowhere near the air I need.
Talked to the same shop known for doing the 60 trim mod, and we are considering taking same turbo further. Throw a different compressor housing on it and doing a super 70 compressor wheel. Says boost could likely be safe at 30psi. I will admit I am not to well versed in these things.
Hot side would be the same so spool would be good I think. I'll have to check measurements to make sure housing will still clear intake manifold.
What do you think?
lgreeley83
What do you think?
Duncansport
02-06-2014, 03:04 PM #2
(02-06-2014, 02:56 PM)lgreeley83 I'm asking for input from you turbo genius guys. I have a Dieselmeken 6mm pump on my 617.
What do you think?
Leaving the hot side would cause issues with back pressure at higher RPMs. I would recommend the HY35 route.
Duncansport
What do you think?
lgreeley83
Mr. Rumbles
02-06-2014, 03:23 PM #3
(02-06-2014, 03:04 PM)Duncansport Leaving the hot side would cause issues with back pressure at higher RPMs. I would recommend the HY35 route.
Hmmm... Don't want floating valves right. What if I said I never attempt to turn 5k rpms?
Also I've read hx30 is good? No hx35 though.
This post was last modified: 02-06-2014, 03:35 PM by lgreeley83.
lgreeley83
Duncansport
02-06-2014, 04:35 PM #4
(02-06-2014, 03:23 PM)lgreeley83
Well Hy35's and HX30's can be found for cheap. Makes more sense then messing with your current turbo as it's turbine is really old technology.
Duncansport
02-06-2014, 05:07 PM #5
There are lots of Chx30's out there. Chinese hx30 clones that are very cheap.
lgreeley83
Mr. Rumbles
02-06-2014, 07:29 PM #6
(02-06-2014, 05:07 PM)raysorenson There are lots of Chx30's out there. Chinese hx30 clones that are very cheap.
Are they worthy though? How well do they hold up?
lgreeley83
02-06-2014, 10:13 PM #7
(02-06-2014, 07:29 PM)lgreeley83
rumor has it that if you bu a chinnese clone, then have a turbo shop balance it, it will last a good while.
I want to say I've heard of real hx30s going for like 200ish from dodge guys upgrading
lgreeley83
Mr. Rumbles
02-07-2014, 07:52 AM #8
I been looking for an hx30 just haven't found one yet. Haven't looked really hard though.
lgreeley83
lgreeley83
Mr. Rumbles
02-07-2014, 09:41 AM #10
I was looking at that same one this morning :-). The only thing I worry about and maybe wrongly so is how they rebuilt it. Maybe they didn't put a 360 degree thrust bearing in it? Maybe that is an easy swap? Would there be a need to rebalance if I swap that? Is a 360 bearing even necessary?
lgreeley83
02-07-2014, 02:55 PM #11
Borg Warner charger would be sweet. One in between a hx30 and hx35 would make for decent spool and power. Or maybe the "super" hx30?
I'd look for a charger with about a 50mm inducer. Any bigger it will be pretty laggy, in my opinion. Borg Warner has the best flowing compressor wheel, because they have the extended top technology
Duncansport
02-07-2014, 03:52 PM #12
(02-07-2014, 09:41 AM)lgreeley83 I was looking at that same one this morning :-). The only thing I worry about and maybe wrongly so is how they rebuilt it. Maybe they didn't put a 360 degree thrust bearing in it? Maybe that is an easy swap? Would there be a need to rebalance if I swap that? Is a 360 bearing even necessary?
I wouldn't go to crazy in the worry department. This turbo will be operating in it's "normal" range while making a lot of power ( for a 617 ).
Duncansport
mike-81-240d
more like mike-84-300d now
427
02-07-2014, 07:36 PM #13
I'd go hy35
mike-81-240d
I'd go hy35
lgreeley83
Mr. Rumbles
02-07-2014, 07:51 PM #14
(02-07-2014, 07:36 PM)mike-81-240d I'd go hy35
I read hx30 spools faster?
I like the forward facing compressor outlet on the Hy35 but how do you clock the housing when the wastegate actuator fitting (whatever its called, where the actuator mounts) is cast into the compressor housing?
lgreeley83
mike-81-240d
427
02-07-2014, 08:00 PM #15
(02-07-2014, 07:51 PM)lgreeley83
No doubt the hx30 spools quicker.
I'm personally still on a oem K26 turbo for now. Planning on doing a modded IP, hy35, W115 intake manifold, egt gauge, a/a intercooler, mechanical fan delete, and maybe a little shot of nitrous to spool the turbo quicker. Currently tackling the IP though... baby steps
Here's a 9cm hy35 on a 617..
http://www.superturbodiesel.com/std/Thre...wered-w116
mike-81-240d
yankneck696
395
02-08-2014, 06:23 AM #16
HY35s are a dime a dozen. I have about 300 HP with the Quadzilla on 7 with my 2001 Dodge Cummins. 239,000 miles on he origional turbo & still sings away. Same rebuild kit as the HX35. Most Dodge guys will probably give it to you, because it has no real performance value in our world.
Ed
yankneck696
Ed
 13 Guest(s)
 13 Guest(s)
