STD Tuning Engine Wrecked a tranny!! and changed to tough one
pmj4147
T04R + TD06
42
01-18-2014, 09:55 AM #1
(Before the start the thread, Sorry for my bad English)
Hi guys!!
Finally i wrecked a stock(Borg-warner) tranny!!!
60,000km with 6mm pump, 5000km more with 7.5mm
Turbo is still a garrett stock. just 1.4bars of boost.
I was cruising on outside circle road with 5th, 2300rpm
Down shifted to 3rd gear, engaged the clutch and crushed.
whatever......
Ssangyong used 3 kind of Manual tranny,
mine was SMF borg-warner. the first one
the second one is Borg-warner DMF type
the third one is 'Hyundai WIA' made DMFtype tranny
(all 3 are compatible with OM60*, M10* motors)
The third one is wat i choose.
it's a stock tranny too. But extremely enhanced durability for high-torque
and it's targeting about 500hp.
it's a typical RR type gearbox.
and i think i can ship it from here if who needed
http://www.hyundai-wia.com/download/automotive.pdf
Click the link and find a A100 model. Catalog says 170hp holding But it's just a stock engine power
This post was last modified: 01-18-2014, 10:01 AM by pmj4147.
2002. 09 Ssangyong Musso SUT
OM662STP + 7.5mm + TD06-25G with customized 84mm compressor(2.4Bar)
2002. 12 Ssangyong Korando
OM662LA 2.9ltr + RS191 5.5mm stock
pmj4147
Hi guys!!
whatever......
F.R.A.S
01-18-2014, 10:25 AM #2
What about this one? M6VR2 looks like a strong one on paper. Does it fit the Mercedes engine?
That gearbox came in the Hyundai Genesis Coupé 3.8 v6 model according to Mr. Google.
This post was last modified: 01-18-2014, 10:29 AM by F.R.A.S.
F.R.A.S
pmj4147
T04R + TD06
42
01-18-2014, 10:55 AM #3
(01-18-2014, 10:25 AM)F.R.A.S What about this one? M6VR2 looks like a strong one on paper. Does it fit the Mercedes engine?
It's for a Hyundai GENISIS Coupe 2.0, 3.8 gasoline engine. as you know
i don't think it'll fit to om60*
Maybe customize the bell housingTongue
This post was last modified: 01-18-2014, 10:57 AM by pmj4147.
pmj4147
F.R.A.S
01-18-2014, 12:14 PM #4
How expensive are those gearboxes where you live?
(01-18-2014, 10:55 AM)pmj4147 It's for a Hyundai GENISIS Coupe 2.0, 3.8 gasoline engine. as you know
F.R.A.S
bigbortha
02-04-2014, 04:20 PM #5
Are the ssangyong om602 gearboxes suitable for power increases?
i am aiming to install an om605 on to a Pajero mk2 and would like to go with a bolt on gearbox instead of an adapter plate and custom flywheel.
Thanks
bigbortha
Thanks
pmj4147
T04R + TD06
42
02-09-2014, 10:43 AM #6
(02-04-2014, 04:20 PM)bigbortha Are the ssangyong om602 gearboxes suitable for power increases?
Thanks
Sorry for late answer.
Yeah it's suitable for a bit
about 7mm pump??
i used about 200,000km with 6mm pump
pmj4147
Thanks
about 7mm pump??
bigbortha
02-10-2014, 03:33 PM #7
thanks for the reply
so it can take a bit of abuse then
bigbortha
pmj4147
T04R + TD06
42
02-11-2014, 02:07 AM #8
(02-10-2014, 03:33 PM)bigbortha thanks for the reply
It can take some of that
But if you can find 2005MY Musso sports, Use that tranny would be way better than standard Borg-Warner
pmj4147
bigbortha
02-11-2014, 06:48 AM #9
thanks for the info
i will keep my eyes open
bigbortha
thanks for the info
