STD Tuning Engine om605 intake manifold
F.R.A.S
02-20-2014, 03:12 PM #1
Ok guys, due to a lot of questions about manifolds, both intake and exhaust I'm willing to share our 605-build.
As you can see the manifold is ready as far as welding and fabrication. Now we gonna blaster it and paint it so it gets a nice even surface.
And yea, the cones are all the way through. The cones are cnc-machined!
Even inside the manifold there are some bits and tricks, but some of that is secret so I have no good photos of the fabrication Cool
F.R.A.S
CRD4x4
CompoundSuperTurboDiesel4x4!
399
02-20-2014, 05:00 PM #2
I like the cone baffles! Nice work! Did you source them from another application or are they custom made?
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
02-20-2014, 05:07 PM #3
Very impressive!
Can I ask is that a NA 606 manifold with one runner cut off? I thought no 605 manifolds were aluminium? (I want one)
Regards, H.
Very impressive!
Regards, H.
F.R.A.S
02-20-2014, 05:19 PM #4
Thanks. They are custom made by our local machine shop.
(02-20-2014, 05:00 PM)CRD4x4 I like the cone baffles! Nice work! Did you source them from another application or are they custom made?
It's from a om606 right, turbo or not I do not remember. But yea, just a runner cut off. Just send me a message and I'll hook you up with one Cool
(02-20-2014, 05:07 PM)Hario Very impressive!
Regards, H.
F.R.A.S
Regards, H.
Eric78
02-21-2014, 02:52 AM #5
I've never seen anything like that before, what do the cone baffles do?
I've an OM605 which I plan to use a air to water intercooler on & was planning that the intercooler be welded to the runners to form the plenum but looking at that I might mount the cooler indendent of the manifold & run a plenum instead.
This post was last modified: 02-21-2014, 03:50 AM by Eric78.
Eric78
erling66
SuperDieselVan
294
02-21-2014, 03:12 AM #6
Strange looking manifoldDodgy To make those cones and put them there is a lot of work so I guess you have a good reason to do that and I guess you have a flow bench and have come up with that solution after a lot of testing? Maybe you have some more info you would like to share with usSmile
HuhCoolTongue
erling66
HuhCoolTongue
F.R.A.S
02-21-2014, 09:54 AM #7
The cone baffles are there to make the plenum stiff. Usually you just use pipes, but this looks better. So it's more or less a design feature.
(02-21-2014, 02:52 AM)Eric78 I've never seen anything like that before, what do the cone baffles do?
There are some secrets inside the plenum Tongue
(02-21-2014, 03:12 AM)erling66 Strange looking manifoldDodgy To make those cones and put them there is a lot of work so I guess you have a good reason to do that and I guess you have a flow bench and have come up with that solution after a lot of testing? Maybe you have some more info you would like to share with usSmile
F.R.A.S
02-21-2014, 12:59 PM #8
ready for some massive boost then because of the cones
F.R.A.S
02-21-2014, 02:41 PM #9
3.5bars (51psi) to start with Cool Aiming for 700hp in this one. But we'll have a twisting road ahead...
We have a Dieselmeken Crazy Jim Edition IP 242cc 7250rpm limiter. But we're planing of four to five big upgrades before we reach maximum power with good durability.
(02-21-2014, 12:59 PM)willbhere4u ready for some massive boost then because of the cones
F.R.A.S
02-21-2014, 03:09 PM #10
please post some video when its running
F.R.A.S
02-21-2014, 04:28 PM #11
It's a while till it's done, but yea, I'll post some videos when it runs.
(02-21-2014, 03:09 PM)willbhere4u please post some video when its running
F.R.A.S
Stamsaas
02-22-2014, 05:44 AM #12
How much would you take to make a custom good-flowing om605 intake manifold? Smile Norway needs one Wink
Stamsaas
F.R.A.S
02-22-2014, 06:14 AM #13
Anything for our brothers in the north west. Send me a message and we'll take it from there.
(02-22-2014, 05:44 AM)Stamsaas How much would you take to make a custom good-flowing om605 intake manifold? Smile Norway needs one Wink
F.R.A.S
 10 Guest(s)
 10 Guest(s)
