Exhaust Line
Exhaust Line
Hi
For a power of between 300.350 hp in a om605, what line of exhaust should I do? 70mm or 76mm?
(03-03-2014, 07:04 AM)bruno_pinho Hi
(03-03-2014, 10:25 AM)Stamsaas I know that, but i asked how much 3" flowes in power.
3" is good enough.
You can push a lot of power trough a small pipe. But bigger is better...
Build 3" that will work for most power outputs. Just keep the heat in the system for as long as you can to maintain gas velocity.
(03-04-2014, 01:32 PM)F.R.A.S 3" is good enough.
