STD Tuning Engine Exhaust Line
Exhaust Line
Exhaust Line
bruno_pinho
03-03-2014, 07:04 AM #1
Hi
For a power of between 300.350 hp in a om605, what line of exhaust should I do? 70mm or 76mm?
bruno_pinho
Hi
Duncansport
03-03-2014, 09:12 AM #2
(03-03-2014, 07:04 AM)bruno_pinho Hi
76mm
Duncansport
76mm
Stamsaas
03-03-2014, 09:24 AM #3
How much is 3" turbo back exhaust taking on a om605 before it needs to be bigger? Smile
Stamsaas
bruno_pinho
03-03-2014, 09:37 AM #4
3"is 76mm ...
This post was last modified: 03-03-2014, 09:37 AM by bruno_pinho.
bruno_pinho
3"is 76mm ...
Stamsaas
03-03-2014, 10:25 AM #5
I know that, but i asked how much 3" flowes in power.
Stamsaas
Duncansport
03-03-2014, 10:58 AM #6
(03-03-2014, 10:25 AM)Stamsaas I know that, but i asked how much 3" flowes in power.
I know ill catch shit for this...but i think 3 inch with a proper muffler and pipe work is sufficient for 550hp
I made 400whp with a gas 4 cylinder (Conquest/Starion) on 2.5 exhaust.
Duncansport
mantahead
03-03-2014, 04:34 PM #7
i dyno 385bhp on om605 with 3 inch straight through exhaust with shit manifold.
mantahead
Stamsaas
03-03-2014, 05:44 PM #8
thanks guys! Smile I ask because I have a problem with the Space, 3" is the biggest I can have past the gearbox, any bigger and I must cut out the floor. I can make the first 50cm or so of the downpipe after turbo in 3,5", if that helps any Smile
Stamsaas
F.R.A.S
03-04-2014, 01:32 PM #9
3" is good enough.
You can push a lot of power trough a small pipe. But bigger is better...
Build 3" that will work for most power outputs. Just keep the heat in the system for as long as you can to maintain gas velocity.
F.R.A.S
3" is good enough.
EDH_Performance
03-06-2014, 05:26 AM #10
(03-04-2014, 01:32 PM)F.R.A.S 3" is good enough.
3" with muffler is to small in my opinion...I feelt biig diference with and without my straight through mufflerSmile
EDH_Performance
