STD Other Projects Coal smoke performance.
  • 1 Vote(s) - 5 Average
Paoli93
03-07-2014, 05:47 AM #1
124w drift car with om606, hx52 and eton m90. Big Grin
Shy
This post was last modified: 03-07-2014, 06:01 AM by Paoli93.
Paoli93
Shy
CRD4x4
CompoundSuperTurboDiesel4x4!
399
03-07-2014, 08:56 AM #2
Looking good. I like your intake manifold and intercooler set up.
Got any more pics of the exhaust manifold?
What are the IP specs?
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
EDH_Performance
03-07-2014, 01:45 PM #3
(03-07-2014, 08:56 AM)CRD4x4 Looking good. I like your intake manifold and intercooler set up.
The first manifold was my old long runner manifold, secound manifold for the hx52 is also made by meSmile
He is running my old 210cc 7.5mm pumpWink
EDH_Performance
Sotvisp
03-08-2014, 02:28 AM #4
Always fun with new projects Keep on Rocking!!
Diesel Power
Sotvisp
Diesel Power
Alcaid
03-08-2014, 05:28 PM #5
Looking forward to seeing this mean machine in the dyno soon Smile
Petter
Alcaid
Petter
03-10-2014, 07:46 AM #6
I like what you did with the intercooler as well. Can we have more pics of the weld job there?
03-10-2014, 02:27 PM #7
Pretty sweet work!
Good job, keep the progress going!
Pretty sweet work!
Paoli93
03-10-2014, 04:46 PM #8
(03-10-2014, 07:46 AM)winmutt I like what you did with the intercooler as well. Can we have more pics of the weld job there?
Thanks Big Grin Yes, i update with more picture now.
After a few hours of work I've come a bit further. Tihi Wink
Here I have some pictures: D
but Where is my radiator? yep, in the wheel well Tongue
One question, anyone have try this pump ?
http://www.ebay.com/itm/DAVIES-CRAIG-ELE...2eb85f3771
This post was last modified: 03-10-2014, 05:08 PM by Paoli93.
Paoli93
Paoli93
03-13-2014, 03:46 AM #9
Paoli93
03-14-2014, 02:42 AM #10
Yes Davies Craig are high quality (US?) electric water pumps.
Paoli93
03-18-2014, 01:38 PM #11
Air intake to eton m 90, home made pulleys and the oil pipes to turbo. Big Grin
Big Grin Big Grin Big Grin Big Grin Big Grin
TongueTongueTongueTongueTongueTongueTongueTongue
This post was last modified: 03-18-2014, 01:52 PM by Paoli93.
Paoli93
Paoli93
03-20-2014, 04:41 PM #12
I have upgraded to Volvo v70 fan on the radiator, connected to wires and relays at 80Amp and 30amp to the water pump Big Grin. Hope you like my solution Confused After this I was tired of scouring car, so I made ​​myself a cool statue that I will have with me at festivals Cool
This post was last modified: 03-20-2014, 05:05 PM by Paoli93.
Paoli93
erling66
SuperDieselVan
294
03-20-2014, 05:16 PM #13
Thank you for sharing your projectSmile Looks like you work alot on it. Photos of your statue?Tongue
HuhCoolTongue
erling66
HuhCoolTongue
Paoli93
07-03-2014, 03:30 AM #14
Hi, im back.. the car has been tested, looks good now. Cool
So, what did you think? Angel
LOL my girbox is empty 5. Exchange 3,67 now is 3,27
This post was last modified: 07-03-2014, 03:44 AM by Paoli93.
Paoli93
sorin_cel
71
07-03-2014, 01:06 PM #15
nice job! monster build!
what size is your exhaust housing on the that turbo?
sorin_cel
Paoli93
07-05-2014, 03:17 PM #16
Thanks, I have 16 exhaust house. Big Grin I will test the car on the track July 11 to 13. my diesel pump are upgrade to 250cc and 8mm elements Big Grin Cool By Dieselmeken AB.
Paoli93
Alcaid
07-06-2014, 12:37 AM #17
(07-05-2014, 03:17 PM)Paoli93 Thanks, I have 16 exhaust house. Big Grin I will test the car on the track July 11 to 13. my diesel pump are upgrade to 250cc and 8mm elements Big Grin Cool By Dieselmeken AB.
250cc is enough fuel to keep up with a HX60 on an OM606 so no lack of fuel yet Wink
Alcaid
Paoli93
07-06-2014, 10:12 AM #18
tihi. I talked to dieselmeken he said Max 220 cc of standartds om606 because the chamber is too small. 180cc and 3,2bar =598hk
so petter, do you think hx52 is to small ? and have you comp map on eton m90? maybe i can change to holset 221 turbo? Big Grin It's too much db form the supercharger.
Paoli93
Alcaid
07-06-2014, 10:43 AM #19
(07-06-2014, 10:12 AM)Paoli93 tihi. I talked to dieselmeken he said Max 220 cc of standartds om606 because the chamber is too small. 180cc and 3,2bar =598hk
HX52 on OM606 should be capable of 550+bhp so depending on how much you want out of it Wink HE221W and HX52 works very good together on an OM606 build in Finland
Alcaid
Paoli93
09-12-2014, 04:55 PM #20
Angel After one track day at gatebil rudskogen.
I found out that the car was very soft behind Angry, tried with double springs back. after that it was not any better,Dodgy I decided to build coilovers from Bmw e36 on the back. so it was. testing at Mantorp Gatebil: D Blush Big GrinBig Grin Tongue
Paoli93
09-13-2014, 12:09 PM #21
Whoa. That's a great rear suspension mod.
S.Engen
09-21-2014, 11:59 AM #22
(09-12-2014, 04:55 PM)Paoli93 Angel After one track day at gatebil rudskogen.
I don't think coilvers will fix the problem.. Upgrade your swaybars, your car have some realy bad bodyroll.
Stock w124 swaybar are sloppy Wink
Check : lakeside race parts) on ebay they have some nice/cheap parts to slam your rearend to the ground.
Btw nice car Cool
S.Engen
Btw nice car Cool
 12 Guest(s)
 12 Guest(s)
