STD Other Projects W124 250d --> 300dt
W124 250d --> 300dt
W124 250d --> 300dt
mbdiesel
04-02-2014, 08:42 AM #1
Hi everybody Big Grin Big Grin
Got myself a w124 250d with manual tran. and its reaaally slow! was at the scrapyard the other day and found a 300tdt, bought it today going to get it asap. Anybody know if its just plug and play? A friend of my got a 250d aswell and then he changed the engine to a 300d non turbo. only had to change the mountplate under the transmission and the arms for the gearshifter, same with the turboengine? and my english sucks hope you guys understand, thank you! Big Grin goin to keep it manual btw!
This post was last modified: 04-02-2014, 08:51 AM by mbdiesel.
mbdiesel
mbdiesel
04-02-2014, 05:11 PM #2
AND, how am i gonna re-wire the glowsystem for the 6 sylinder instead of 5? Smile
mbdiesel
04-03-2014, 03:20 AM #3
All parts required are on 300TDT, like 6-cylinder glow relais, engine wiring loom for electronic idle etc. very simple. Also 300TDT has oil cooler in wheel housing, needs some brackets welded on. All on the donor car, you'll see. Donor car = you construction plan Wink
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
mbdiesel
04-04-2014, 03:13 AM #4
Can i use the old electric idle from the 5 cylinder? Smile Can I run the engine on 10w40 fully synthetic oil?
Thanks for answers Smile
This post was last modified: 04-04-2014, 05:02 AM by mbdiesel.
mbdiesel
