STD Tuning Engine om605 intake manifold
F.R.A.S
05-30-2014, 01:07 PM #1
Here is some pictures of an aluminum intake manifold we are building for a om605.
You will see this pictures and pictures of it done. Inside is Top Secret Tongue No just kidding, it's nothing secret about it. But you have no business copying our work.
The inside will have a deflector of some kind to divert the air more evenly to the cylinders to avoid one or two cylinders running cooler than the others and one or two running hotter...
Sorry for the English regarding this. Have no clue what the correct terminology are so I'm just going with the flow here Cool
More pictures HERE
F.R.A.S
More pictures HERE
hooblah
06-02-2014, 01:25 PM #2
If I've understood this correctly, having a tapered inlet manifold for a turbo'd engine accounts for pressure loss at the cylinder furthest from the air inlet?
I see tapered manifolds used on petrol engines, but why is it we don't see much of this on this forum or for diesels in general?
hooblah
F.R.A.S
06-02-2014, 04:25 PM #3
On a petrol engine you have a throttle body before the plenum (intake manifold), when opening the throttle you have some fast flowing air coming in the intake and that air will take the most easy way in to the cylinders causing some cylinders to go lean and some rich.
When going ITBs you already have the intake manifold filled with air and therefore more even air flow in to the cylinders.
Diesels have no throttle so therefore there is no sudden rush of air (just like the ITB)
How ever it is wise to divide the air for an even flow in the case of sudden rushes of air, both on diesels and ITB petrol engines. You can let go of the "throttle" (pedal) and step on it, if you're at the right revs you'll have full boost in the fraction of a second and that's when it's do or die for your engine Wink
/ F
(06-02-2014, 01:25 PM)hooblah If I've understood this correctly, having a tapered inlet manifold for a turbo'd engine accounts for pressure loss at the cylinder furthest from the air inlet?
F.R.A.S
/ F
F.R.A.S
06-03-2014, 01:49 PM #4
This is where the magic happens Cool
I hope I have some pictures of it all done tomorrow.
F.R.A.S
Duncansport
06-03-2014, 02:11 PM #5
(06-03-2014, 01:49 PM)F.R.A.S This is where the magic happens Cool
Nice work, get that guy a stool!
Duncansport
06-03-2014, 03:23 PM #6
LOL! That's exactly what I was thinking. Very nice work too!
F.R.A.S
06-03-2014, 04:11 PM #7
Hey guys, that's an hydraulic welding table so he can adjust the hight to fit Wink He doesn't need a stool Big Grin
Thanks for the replies. Hope I can give you a finished picture in the white tomorrow.
F.R.A.S
F.R.A.S
06-04-2014, 09:16 AM #8
Yea, almost finished in this picture. Just a 45-degree angle in the end a little bit of tube is missing.
Tomorrow it will be (sand) blasted and painted. Pictures of the finished result will appear in the owners project thread here on the forum Tongue That means that you will not see the finished result before him Big Grin
Now we just cross our fingers the damn thing will fit Cool
F.R.A.S
Mark_M
06-06-2014, 05:57 PM #9
What diameter/hight is that? In some pictures it looks absolutely massive in others not so much.
Nice job by the way.
Mark_M
F.R.A.S
06-07-2014, 02:34 AM #10
Hi, thanks. It's 4" or 100mm.
(06-06-2014, 05:57 PM)Mark_M What diameter/hight is that? In some pictures it looks absolutely massive in others not so much.
F.R.A.S
Mark_M
06-07-2014, 04:58 AM #11
Its the not so massive then. Thanks for the info.
Mark_M
F.R.A.S
06-07-2014, 07:44 AM #12
I think it's just the right size for the car it's going in to.
Had some problems with the paintshop on Thursday and on Friday we celebrated the Swedish National Day so that's one day off. The intake manifold is still in the white. I really hope the painter can come through on Monday so we can ship this out on Tuesday.
I really looking forward to see the thing mounted in the car. Big Grin Will be one fast little om605.
(06-07-2014, 04:58 AM)Mark_M Its the not so massive then. Thanks for the info.
F.R.A.S
Stamsaas
06-29-2014, 12:27 PM #13
The finish Product looks great!! Big Grin
[Image: 20140628_134207_zpsed52685b.jpg]
Stamsaas
07-08-2014, 09:27 AM #14
Could you please link the project thread this is used on?
I have almost tried to find it myself.. Tongue
07-08-2014, 11:42 AM #15
It's the corolla build. How do you almost try to find something?
07-09-2014, 03:04 PM #17
When I saw the welding photos all I could hear in my head was "VVVVVVRRRRRRRRRRR"
F.R.A.S
07-14-2014, 01:05 PM #18
Thanks guys and thanks Alex (Stamsaas). This came out real nice and it's a product I'm proud of Big Grin Hope to see it in the car really soon Smile
F.R.A.S
Eric78
12-16-2016, 08:48 AM #19
(06-29-2014, 12:27 PM)Stamsaas The finish Product looks great!! Big Grin
How much for an intake mafold like that one?
Eric78
Evgeniy1987
12-17-2016, 04:41 AM #20
The manifold looks nice!
Do you have proof from for example SolidWorks Flow Simulation that that thing will actually work ?
It is difficult to simulate including the dynamic behavior of closing/opening valves, but it is already a big gain if it flows well statically..
Evgeniy1987
 14 Guest(s)
 14 Guest(s)
