STD Tuning Engine Turbo Suggestion for a OM617
Actros617
What's a spark plug???
49
09-13-2009, 09:17 PM #1
Anyone know a good turbo replacement for a OM617.95 for a 300SD, it can be a vnt or a non vnt...
Actros617
09-13-2009, 09:59 PM #2
GT2256V, GT2359V and the GT2559V are all great.
alesbm
12-05-2009, 03:52 PM #3
Turbo Suggestion for a OM602962
Anyone know a good turbo replacement for a OM602962 for a 250D turbo, it can be a vnt...
I m looking for Garett 2256V or someting similar,
The engine is in mercedes benz G end using for extrem offroad
end i need more torque in low renge
alesbm
GREASY_BEAST
12-07-2009, 12:00 AM #4
If you don't want to do the work of a VNT swap, a Holset HX30 will work fine. Spools enough to start triggering the ALDA at about 1800rpm, 4-5psi by 2000-2100, and up rapidly from there. That is with an un-adjusted ALDA, if I adjust it a little things will happen faster. Furthermore, the turbo is WAY more efficient than either of the stock turbos, EGTs dropped considerably after installing and running at 15psi. Its been a while since I did the calculation, but I believe this turbo is only good for about 250hp worth of fuel, so if you have your sights set on a higher target you should find a big VNT.
This post was last modified: 12-07-2009, 12:01 AM by GREASY_BEAST.
GREASY_BEAST
W116Lorinser
OM617.95
147
12-07-2009, 08:26 PM #5
is the Holset HX30 a direct replacement for my stock turbo in my 1980 300sd..... will it offer acceleration then stock.
also would the HX30 be better then the kkk k26
thanks
W116Lorinser
thanks
kmaser
Turbocharged G-Wagen
125
01-18-2010, 11:36 PM #6
can anybody answer this
kmaser
01-18-2010, 11:49 PM #7
It would take some fabrication to fit and work its not a direct replacement! As for power it won't add any unless you add a lot more fuel! and a custom injection pump is big $$$
It will take longer to make boost as it is a large turbo in reality it'll loose hp until you had an injection pump that could fuel it
diesel's make hp from adding fuel but it will get hot so more boost is needed to cool it off!
adding air wont make hp only adding fuel will but air is needed when adding fuel to keep it from melting down
the k26 is you best bet for a stock injection pump!
This post was last modified: 01-19-2010, 10:22 AM by willbhere4u.
