STD Tuning Body Mods W123 rad options to hide/replace overflow bottle
bricktron
'77 240D
174
08-07-2014, 12:55 AM #1
want to stop seeing the overflow bottle. along with staying in cool climates, i am looking into a rad swap, plus either a siphon recovery bottle or that fancy non-expansive coolant they now have.
i have a turbo 300D setup right now. tried to put in a 240D radiator and nonpressurized overflow bottle, but didn't realize the oil coolers were different too, so i had to stop until i get a 240D cooler.
do all the rads have the extra lower section for (i think) auto trans? has anyone come up with another use for it?
are NA 300D rads/coolers different from the 240D ones? any other candidates to consider?
bricktron
08-07-2014, 12:40 PM #2
I always cap the transmission cooler holes to keep junk out. Some offroad guys use them to heat water on the campsite for bathing Smile
You can get a radiator cap that splices into the large radiator hose, allowing you to use a regular hidden non-pressurized coolant bottle.
With an electric fan, people have said that it rarely kicks on-so the assumption is the standard radiator is properly sized.
bricktron
'77 240D
174
08-08-2014, 02:00 AM #3
right on. that rad cap is just what i need. i looked for such a part before without success and i guess i will look again as it's so much simpler {tm}. i am guessing the hose splice thing provides a fill stem as well as a pressure valve - never sure how i could fill this radiator without the pressure bottle.
bricktron
08-08-2014, 07:52 AM #4
There are multiple options and retailers, here's jegs cap:
http://www.jegs.com/i/JEGS-Performance-P...8/10002/-1
[Image: 555-53098.jpg]
bricktron
'77 240D
174
08-08-2014, 09:14 PM #5
ordering. thanks S=B.
bricktron
bricktron
'77 240D
174
08-13-2014, 12:45 PM #6
i found a filler from a dodge which i think will work. already have one of these:
http://www.jegs.com/i/JEGS+Performance+P...0/10002/-1
[Image: 555-511000.jpg]
can anyone tell me how the intake and outlet are supposed to be plumbed up to the hose filler barb? i thought there was going to be just one hose for both directions of coolant flow (i.e. either overflowing or being sucked back to the rad, depending on temperature).
bricktron
08-13-2014, 01:32 PM #7
Plumb the bottom one to your overflow port, and the top one somewhere it can vent.
bricktron
'77 240D
174
08-13-2014, 07:05 PM #8
so complicated!! thanks again.
bricktron
 6 Guest(s)
 6 Guest(s)
