STD Other Projects Planning om603 hx35
Planning om603 hx35
Planning om603 hx35
bl4z33r
08-19-2014, 03:28 PM #1
Hello I Want to buy a w124 with om603 turbo.
but before i buy the car i want a list of what parts i need.
thats why i want some help.
I thinking around 350hp
What do you think about Holset hx35
but is it better to go for the Dieselmeken 7.5mm or the 8mm ?
please explain me why
and is it some more i need to get this running
this is my first diesel Prosjekt.
bl4z33r
Gforce
08-19-2014, 04:23 PM #2
you also need an intercooler and your intake manifold needs to be changed
Gforce
bl4z33r
08-19-2014, 05:43 PM #3
(08-19-2014, 04:23 PM)Gforce you also need an intercooler and your intake manifold needs to be changed
okei Wink can i go for the 8mm pump? what is the downside ? or is more better?
bl4z33r
bl4z33r
08-24-2014, 04:48 PM #4
nobody have some advice? for me ?
bl4z33r
08-26-2014, 07:14 AM #5
8mm elements will give you some overhead for fueling if you wish to go for more boost/power in the future. There are mixed reviews about idle quality with bigger elements but everyone seems to think they will be fine.
Turbo,
manifold,
pump,
elements,
fitting elements,
intercooler,
ALDA,
pipework,
EGT gauge,
Boost gauge,
Turbo,
manifold,
pump,
elements,
fitting elements,
intercooler,
ALDA,
pipework,
EGT gauge,
Boost gauge,
08-26-2014, 10:52 AM #6
If you have an early 603, make sure you at least replace the head gasket before going big with boost and fuel.
IMO, 7.5mm elements will make more power than your 603 can handle.
Insane190d
08-26-2014, 07:11 PM #7
I have an 8mm pump on my om603 idles fine, only have it about half the fuel it will flow but its there when I want more
Insane190d
bl4z33r
08-29-2014, 11:32 AM #8
what turbo you have insane190d ? and what boost do you have?
bl4z33r
Insane190d
09-03-2014, 06:46 AM #9
(08-29-2014, 11:32 AM)bl4z33r what turbo you have insane190d ? and what boost do you have?
Its an hx35 off a 2nd gen dodge cummins. I went to home depot and bought a 30psi boiler pop off valve and plumbed it into my intake, works pretty good blows off at 30 and stays between 27 & 30psi
Insane190d
 7 Guest(s)
 7 Guest(s)
