STD Tuning Engine OM606.962 - TB70 - Boost Problem
DaimlerDK
08-23-2014, 08:07 AM #1
Hello,
I have a big Problem, I built an OM606.962 in my W124.... Motor & Gearbox works fine, but I have no boost....
Its an TB70 from Turbobandit with external Wastegate... Wastegate closed... I cut the pressure from Turbo to the Wastegate, and tested, but no boost, maximum 0.2 bar HuhHuhHuh
Can anybody help me?
Kay
DaimlerDK
Hello,
Kay
CRD4x4
CompoundSuperTurboDiesel4x4!
399
08-23-2014, 08:40 AM #2
Sorry to hear you struggle!
What modifications have been made to the Injection Pump (IP)? Increased fueling is required to push the exhaust turbine up to speed and get full boost.
Are you using an intercooler? Sometimes they leak. Also, using one that doesn't leak and gets good airflow will help.
Keep up the good work and be sure to share/teach us what you find.
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
DaimlerDK
08-23-2014, 01:32 PM #3
I solved the Problem.... Big Leak in the Intake Manifold ;-)
DaimlerDK
mario
08-23-2014, 03:12 PM #4
Happy days and let there be boost
mario
08-28-2014, 07:28 AM #5
Do you have any pictures of the install? INterested in Turbobandit hardware!
Thanks,H
Thanks,H
