om603 6mm elements
om603 6mm elements
the om605 whith 6mm (stock) can do 260hp.om603 whith 6mm ip can produce 240?or less?
Pedro , Is what i already have told you, I guess....
Om605 with 6mm on dyno 274hp on crank.
http://www.maxxtuning.se/kundbilar/effek...w123--jim/
(12-26-2014, 10:47 AM)MrHope Om605 with 6mm on dyno 274hp on crank.
(12-26-2014, 03:31 PM)bruno_pinho(12-26-2014, 10:47 AM)MrHope Om605 with 6mm on dyno 274hp on crank.
I do not believe in 174 to 1.5bar...
(12-26-2014, 04:35 PM)Petar(12-26-2014, 03:31 PM)bruno_pinho(12-26-2014, 10:47 AM)MrHope Om605 with 6mm on dyno 274hp on crank.
What don't you believe ? That engine is only making 380 NM's of torque but with the torque curve shifted up in the rpm range to make more power.
That's not 6mm elements in that video and the owner Jim is a friend of mine.
6mm can't ever do 300hp forget about that.
(12-26-2014, 05:08 PM)F.R.A.S That's not 6mm elements in that video and the owner Jim is a friend of mine.
