STD Other FS / WTB / Buying guides FS Toyota OM 617 conversion Brackets and Flywheel Adapter
zeeman
12-21-2014, 02:47 PM #1
TD Swaps Toyota truck Om 617 conversion brackets and flywheel adapter.
Power steering pump mount that moves the pump back and inch for radiator clearance. A matching bracket that moves a GM alternator to the drivers side and a A/C bracket for the passenger side that uses the Toyota A/C compressor.
Also a flywheel adapter to adapter to adapt the Toyota flywheel to the Om 617 crankshaft.
$150.00 for all plus shipping. PM me or call or text 208-683-0465 Ask for Ron.
Northwestdieseloffroad.com
zeeman
SurfRodder
Jackass Extraordinaire
611
12-23-2014, 08:17 PM #2
How far back does the adapter move the flywheel? Does the om617 starter engage the Toyota flywheel properly? How thick of an adapter plate is it designed for? Is this a one off or are you selling multiple kits? Thanks in advance.
(12-21-2014, 02:47 PM)zeeman TD Swaps Toyota truck Om 617 conversion brackets and flywheel adapter.
OBK# 62
SurfRodder
OBK# 62
zeeman
12-24-2014, 02:13 AM #3
(12-23-2014, 08:17 PM)SurfRodder How far back does the adapter move the flywheel? Does the om617 starter engage the Toyota flywheel properly? How thick of an adapter plate is it designed for? Is this a one off or are you selling multiple kits? Thanks in advance.
The adapter plate is 1/2" thick, it uses the Toyota flywheel and starter in the stock location. I used a 2kw Tacoma cold weather starter which I adapted for the added torque for the diesel and a turbo 22r flywheel for a bigger clutch which I got from Marvin Crawler.
I ended up using a different radiator so I didn't use the brackets I had purchased and just used the adapter plate. I had an extra flywheel adapter made for a pattern.
All this was bought from TD Swaps in Portland Oregon. Enclosed are some pics of the Toyota truck I am finishing with an added intercooler.
zeeman
hybridyota
01-01-2015, 09:40 PM #4
Sorry to thread jack. What rad did you go with?
hybridyota
