STD Tuning Engine m pump in 605
m pump in 605
m pump in 605
gary andrews
4x4 builder
48
01-06-2015, 05:17 PM #1
hi i have just fitted my m pump with 7.5 elements to my 605 but to get it in i had to remove oil cooler and oil fitter housing. so do i need to block the water ways up e.g. core plugs,and the fitter housing do i need to get another one if so off what ? or what is the done thing for to sort these two cheers
c250 std at mo
gary andrews
c250 std at mo
EDH_Performance
01-06-2015, 08:47 PM #2
(01-06-2015, 05:17 PM)gary andrews hi i have just fitted my m pump with 7.5 elements to my 605 but to get it in i had to remove oil cooler and oil fitter housing. so do i need to block the water ways up e.g. core plugs,and the fitter housing do i need to get another one if so off what ? or what is the done thing for to sort these two cheers
You should be able to have the oilcooler there as that motor comes with mechanical m-pump from factoryWink
Maybe you have the om602 mechanical m-pump with the funny lump on the back of the pump?
EDH_Performance
gary andrews
4x4 builder
48
01-07-2015, 03:01 AM #3
yes that sounds like the pump i have
c250 std at mo
gary andrews
c250 std at mo
F.R.A.S
01-07-2015, 05:18 AM #4
Cut a flat plate to mount on the back of the pump Smile
F.R.A.S
01-09-2015, 09:09 AM #5
Got a picture mate??
gary andrews
4x4 builder
48
01-11-2015, 05:05 AM #6
ive blanked the core plugs and fitter housing for now ill use external cooler later ,cheers
c250 std at mo
gary andrews
c250 std at mo
Druk
01-11-2015, 05:25 AM #7
Are you sure these oilway items aren't full-flow and you'll be starving the bearings of lube?
Druk
01-12-2015, 11:50 AM #8
Well OM606 uses front mounted oil cooler so for future reference could use a OM606 oil filter housing and connect the two oil fittings together in a loop? Assming it also blocks off the OM605 water fittings in the block?
01-13-2015, 04:59 PM #9
hy there,
best way of doing: go in a scrap yard buy a oil filter support from a G o M, those come with oil radiator any motor have them, even the sangyoung 4 whellers. 601,2,3,4,5,6 are interchangeable, so anyone goes.
to cover the cyl head holes use expansion taps,(dont know the correct name in english) can buy them from MB or in any automotive retail store.
regards.
hy there,
regards.
