STD Tuning Drivetrain 6spd manual list, pdf
raidaru
12-25-2014, 05:08 PM #1
As you can see in the atachment, there are plenty of 716.6xx trannys, let's hear everyone's experience with these boxes and try to solve the number misterys. Johann used 716.654 box on his STD w124 succesfully. So are the higher numbers better or not?
.pdf
Overview of major assemblies.pdf
raidaru
.pdf
MrHope
01-10-2015, 12:42 PM #2
Nice find!
but does anyone know the the measurements between:
IN Metric Big Grin
1, from motor flange to gearshift ?
2, from motor flange to utput flange ? (without the rubber ring)
Hope u like my photoshop skills! Cool
This post was last modified: 01-10-2015, 12:43 PM by MrHope.
W124 300D 1985 (daily driver)
MrHope
Nice find!
IN Metric Big Grin
Max
Turbinaaa
87
01-10-2015, 01:27 PM #3
(01-10-2015, 12:42 PM)MrHope 2, from motor flange to utput flange ? (without the rubber ring)
I measured 53 cm at my 716.641 from 270cdi,
Greets
Max
Max
Greets
Max
MrHope
01-10-2015, 04:46 PM #4
(01-10-2015, 01:27 PM)Max
Greets
Max
so its about the same as a 5spd ? if im not totally wrong my 717.460 is about 50cm~
MrHope
Greets
Max
Max
Turbinaaa
87
01-11-2015, 07:40 AM #5
Hi,
the "normal" 5-Speed (717.411 etc..) are shorter.
My 717.430 (190D 2,5 Turbo 5-Speed) ist about 48 cm
The 717.450 (Dogleg from m104 3.0 24V) ist about 53 cm
Tahts all i got Tongue
Greets
Max
Max
Hi,
Greets
Max
