STD Other Projects W201 Om605 Build
W201 Om605 Build
W201 Om605 Build
Kuisma
02-08-2015, 05:37 AM #1
Hello everyone! My name is Joonas and im from Finland. Heres my w201 190D Sportline ST project. The car was originally with n/a om602+5v manual+open diff.
Nowdays it has Om605 Tbo engine and Bmw 5v ZF gearbox+ 2.87 ASD diff from w124 4matic.
Heres some pics off the car, ill add more pics/info on next post.
[Image: 20141017_150800_zps8fce4a0c.jpg]
[Image: 20141015_182156_zpsadc89126.jpg]
[Image: FB_IMG_1413191481522_zps991a8ec8.jpg]
Kuisma
Kuisma
02-08-2015, 07:05 AM #2
New 8mm mynä IP
[Image: 20141219_222349_zps410d8589.jpg]
[Image: 20141219_222321_zps73fbe938.jpg]
5v bwm ZF welding done and ready to go
[Image: 20140830_000918_zpsb8ab3a45.jpg]
New turbo: Holset hx40 super with billet comp wheel.
[Image: 20140703_180834_zps7b87fb5e.jpg]
[Image: 20140712_142611_zpsf6e67aed.jpg]
Awesome tic welded exhaust manifold, made by Pt_Racing (Pyry Takkunen from Finland)
[Image: FB_IMG_14056118248314107_zps08e7546a.jpg]
VHT black Flame Proof coating
[Image: 20140809_104109_zps44f7e984.jpg]
[Image: 20140809_104059_zps9542a156.jpg]
[Image: 20140908_185806_zps98fce0ca.jpg]
[Image: 008.JPG]
Old pics from last summer, i will update better pics later.
Engine specs: Stock om605 turbo, new bearings, piston rings, gaskets etc. Stock intake manifold atm, i will make new from Om606 manifold with AMW wrc plenum. Heres my old om606 with same kind of manifold:
[Image: 20140223_034504_zps6d4d2c71.jpg]
Brake update. New discs:
[Image: IMG-20141107-WA0002_zpsf6b19125.jpg]
[Image: IMG-20141107-WA0001_zps30f12004.jpg]
Calibers sand blowed+coated with VHT brake caliber paint. Time to bake:
[Image: 20141211_153745_zps3ff216a8.jpg]
Ready
[Image: 20141226_202446_zps4c152d92.jpg]
Dyno session from last week. Original lift pump stopped to flow on higher rpms so the power didnt grow up from 4800rpm. Next time i will make new 10mm fuel lines and install Holley 150gph eletric pump.
[Image: IMG_55056658914929_zps8fff6a69.jpeg]
https://www.facebook.com/video.php?v=102...1663594892
460hp 670nm pull.
Kuisma
New 8mm mynä IP
[Image: 008.JPG]
Ready
460hp 670nm pull.
bmartins
02-08-2015, 08:22 AM #3
How....nice W201.....keep the job....
bmartins
Max
Turbinaaa
87
02-08-2015, 05:55 PM #4
Great Build !!!
And impressive Dyno Results Cool
Greets
Max
Max
Great Build !!!
Greets
Max
Kuisma
02-08-2015, 06:03 PM #5
Thanks! Smile
Kuisma
Thanks! Smile
USMCRAIDER
10-17-2017, 08:37 PM #6
Very nice! How did you get rpm, and spedometer to work with bmw zf?
USMCRAIDER
