STD Tuning Engine Om605 pump on om602
Om605 pump on om602
Om605 pump on om602
k2igukast
02-10-2015, 07:01 AM #1
Is it possible to install an om605 turbo fuel pump on a om602? I am aware, that its fuel flow is partially controlled electronically. Should I install it together with the electrical parts?
k2igukast
baldur
Fast
509
02-10-2015, 07:12 AM #2
Yes if you have all the electronics to control it, it will drop right in. Note that the 605 has an engine speed sensor on the flywheel which you must fit or duplicate.
Baldur Gislason
baldur
Baldur Gislason
k2igukast
03-02-2015, 10:53 AM #3
What hp expected full loaded om605 pump on om602? I dont need ECU, right?
k2igukast
03-02-2015, 04:07 PM #4
funny , how do u imagine to control a EDC pump without a ECU Wink
k2igukast
03-03-2015, 02:08 PM #5
Oh fuck, my bad.
k2igukast
Oh fuck, my bad.
baldur
Fast
509
03-03-2015, 02:57 PM #6
(03-02-2015, 04:07 PM)barrote funny , how do u imagine to control a EDC pump without a ECU Wink
Easy, just rig up a throttle lever to the rack. It won't be possible to idle but it'll drive fine otherwise.
Baldur Gislason
baldur
Baldur Gislason
Petar
7.5mm M pump
459
03-03-2015, 03:21 PM #7
(03-03-2015, 02:57 PM)baldur
No rev limiter either lol  Big Grin
Seriously take the pump from your 602 engine and the 605 pump and have a shop swap the elements and adjust the pump.  Wink
Petar
03-03-2015, 05:15 PM #8
(03-03-2015, 03:21 PM)Petar
very nice idea u boys gave me, next saturday i will hook a string pushing the rack forward, and conected to the full pedal.
i´ll cal it the "afterburner"
good luck though.
good luck though.
