tomnik elements!
tomnik elements!
(03-10-2015, 03:35 PM)Joystick So what type pump is a om606 turbo pump? And wich type is a 606 non turbo pump?
(03-10-2015, 06:10 PM)Joystick Ah Thanks. And exactly what is a governor?
My pump goes to dieselmeken anyways so no 6mm elements here
(03-10-2015, 03:51 PM)Petar(03-10-2015, 03:35 PM)Joystick So what type pump is a om606 turbo pump? And wich type is a 606 non turbo pump?
Both are M pump. But in the W210 the mechanical governor was replaced with the EDC governor.
EDC and mechanical pumps share the same elements but the difference is there is no governor on the pump, it is controlled by the ECU. It is only a simple solenoid that moves the rack and the rack position sensor in the pump.![]()
The 606 turbo pump has bigger 6mm elements versus 5.5 elements in the older pumps.
Those elements can be swapped right over to older mechanical pumps and they work perfectly
(03-26-2015, 05:55 PM)barrote(03-10-2015, 03:51 PM)Petar(03-10-2015, 03:35 PM)Joystick So what type pump is a om606 turbo pump? And wich type is a 606 non turbo pump?
hy petar, do u happen to know how is the rack position measured?
does it have anything to do with the imput voltage suplied to the electroactuator? or it is a completely dif circuitry?
once that signal is deciphered, it sounds good for controlling a variable vane turbo (or even a supercharger).
