re-timing injection pump
Due to having a catastrophic failure on my 83 300sd, I want to make sure my injection pump is still timed correctly with crank and cam.
Wanted to know how to do it? Cant seem to find much.
Thanks
(10-13-2009, 10:49 PM)tony597fitter Due to having a catastrophic failure on my 83 300sd, I want to make sure my injection pump is still timed correctly with crank and cam.
Thanks
Thanks
(10-14-2009, 08:12 AM)tomnik(10-13-2009, 10:49 PM)tony597fitter Due to having a catastrophic failure on my 83 300sd, I want to make sure my injection pump is still timed correctly with crank and cam.
Thanks
for the cam timing just look at the marks cam/cam bearing support.
What kind of failure? The IP timing should not get lost except the chain jumped.
Tom
Thanks
Tom
